E46 parts & maintenance
Latest damage. My Xenon Control Unit aka ballast went kaput recently.
Initially I thought the bulb is the culprit so went to Eurocar motorsport to "upgrade" to 6000K HID bulb but the workshop below Eurocar checked and told me is the control unit :beaten:
Anyway went to another mechanic for a second opinion and the outcome still the same.
Xenon control unit approx RM 1500 from Bavarian Auto - Jln. Ipoh with 1 month warranty after much indignant protest. Initially no warranty.
Another blow to my already bleeding pocket...
- Fan belt bearing/labour $80.00
- Fan belt tensioner $148.00
- Oxygen sensor/labour $650.00
- Service - Oil filter/engine oil $298.00
- Radiator/labour (had a hairline crack) $680.00
- Thermostat / fixing $200.00
- Radiator top hose $135.00
- Radiator coolant $26.00
- Oil sump gasket/labour $250.00
- Oil ring washer (9 pcs) / Gear oil top up (2 ltr)/labour $600.00
Total $3067.00
Hope my baby appreciates all these and runs well.
RM 298 foroil change? I can get it done here in Kuching for RM 175, did u do it in AB?
okow's price is for a 6 cyclinder...lah
are u saying u r getting RM178.00 for 6 potters in Kuching?
btw, okow apa engine oil u r using?
NKTOB: Same as yours....i believe.. fully synthetic Castrol.
he he, sorry for my ignorant, yes, mine is 4 pot. Not sure how much is 6 pot in kuching, i'll try to find out.
1.9L 4 potters are closed to 5 litre dude
i just changed my to new CASTROL EDGE xW-40
not CASTROL EDGE SPORT which is xW-60
So far very smooth n quiet :)
Originally posted by bibendum@Jul 10 2006, 01:55 PM
4 potter is using 4L... 6 potter 6.5L..
yes u r right, 4 litre for 4 potter 318i just nice touching the max line (most important not to overfilled over the max line)
leakwoon, u overfilled yours with 5 litre
Bro leakwoon,
My E46 is 2.0 valvetronic only used 4.25 liters of engine oil. I think you better get yours oil level checked. Consult your manual and see what is the right amount of engine oil.
Did you do your oil change at your regular shop?
ya la leakwoon, siao meh u put an extra litre, unless u got engine leak la :D ...as long as your dipstick indicate oil level in the middle you're ok liao bro...
bro FYI engine oil overfill will damage the engine in long run, this is worse than fill up less oil lah...always get the mech to fill 4 litre only for your car, not enought then only fill the little extra, mine 6.25 also i put 6 only due to some old still inside the engine.
totally agree, mine 4 litre i fill 3.8 (anyway guys, maybe if there is a need, we can make a new topic on this) affraid later moderator comment that this is for parts & maintenance.
serious leakwoon, 2 years of driving with only 4 litre each renewal, never gone above that...
Car stalled at traffic lights..after restarting, car can barely move. Can't even reach 100km/h...all the cars are zooming pass me. I thought I saw a baby stroller over taking me too.... :(
Went to ah Meng, found that the cam sensor koyak....
damage done...RM750 for both the sensors including labour....
Hi Guys,
Just changed my brake pads and disc below is th cost:-
Disc: RM230 (a pair)
Pads: RM105 (a pair)
Labour: RM55
Next works shall be the klocking sound from the strearing area.......dunno if its the stearing rack or the bushes....
my e46 318 right hand side mirror got broken cos' of slight accident with another. wondering how much a new replacement / potong parts cost. any brother can help? TQ
The wide angle heated mirror would cost you about RM 340 and there is a cheaper alternative but it is neither heated nor wide angle.
go potong at jln puchong from old klang road ........specialise in bmw and mb parts
