bro leakwoon...finally manage to purchase my bimmer....320i....so, where do you advice me to send my car for my 1st inspection....mileage is 49k...no tampered tampered one....heh heh...thnks...Originally posted by leakwoon@Jun 6 2006, 07:47 PM
put there 1 day
n ask them test kao kao
spare tank broken when the way to genting and need to tow to my mechanic in tmn mayang on 8/6/06 and back to genting again after change the spare tank, the charges as below :Originally posted by wks@Jun 7 2006, 09:05 PM
have sent my car to workshop in tmn mayang PJ today, so far so good, the charges as below:
1. cover plate RM80.00
2. fuel filter RM220.00 (additional work)
3. hose clip RM5.00
4. radiator coolant original RM45.00
5. labour charge RM80.00
TOTAL RM430.00
up to date the coolant light did't on.
i changed my spare tank only cost RM380.00, why your so expensive ? is it including thermostat which located bottom of spare tank ?Originally posted by ylkhor@Jun 9 2006, 12:40 AM
today replaced radiator at ah meng usj, cost RM680 + RM20 labor. Also change the accelerator throttle cable for RM100 ...now gas pedal soft-soft and smooth-smooth, previously quite tight and heavy to depress pedal...
Vinson,Originally posted by vinson@Jun 6 2006, 04:12 PM
Fuel Pump (original Siemens VDO) NEW RM 400
Adjustor valve on the manifold NEW RM 550
+1 dented sport rim RM 45
Fire,Originally posted by fire@Jun 6 2006, 05:53 PM
Car aircon on the driver side not cold, but passenger side are cool sent for checking & re-fill the Gas..RM95(gas) + RM28(leak detector)..RM123 burn...v
vinson, is these part are original ? because i changed few day ago in tmn mayang, PJ the mechanic charged me as below or can refer my thread :Originally posted by vinson@Jun 15 2006, 11:16 AM
Changed more parts...more for a just in case after getting some advice from bmwcar2. Many thanks bmwcar2. I was told by bmwcar that these parts will wear out when it reaches the 5 years mark...so better change. Dun want water drooling from my car in the middle of a traffic jam.
Camshaft sensor RM 348
Thermostat RM 140
Expansion Tank RM 230
Coolant (Merc punya) RM 35
Another dent in the pocket :beaten:
do u have difficulty in starting the car? (4 or 5 crank only can start). If u have this problem, i think u have a clogged idling valve. anyway bro, u should start a new topic or try searching for similar post coz this is for list of parts and maintenanceOriginally posted by `g0tHic`@Jun 16 2006, 04:11 AM
sifus out there pls help! My car seems to idle a little bit when i stop at traffic lights and the engine died 2 times b4 when the car stopped but everything seems ok when i start the engine again...went to mech for diagno...no errors shown...wats the problems with my car??
Bibendum,Originally posted by bibendum@Jun 16 2006, 09:02 AM
Hi there..
Nobody mentioned about Bosch Wiper Blades @ RM170... which is quite a shock to me.
Is it the Bosch Super Plus made in Belgium? I just got them for my E46 for RM150/set which i think is already shocking!!Originally posted by bibendum@Jun 16 2006, 09:02 AM
Hi there..
same with me, but i only purchase the refill from Brother accessories in PJ uptown for RM 60 including installation recommended by tank34Originally posted by leakwoon@Jun 16 2006, 10:29 AM
I m using dura Edge Silicone
so far so good![]()
