E46 Part and Service Cost II
kee;654040 said:
12/7/2011@Hin Leong Tyre, Klang
Achilles 235/35/19 (2 pcs) = RM800
Rotate existing tyre (2 pcs) = FOC
Balancing + Alignment = RM50
Alignment rear chamber = RM50
Total = RM900
The price is damn cheap, i even not dare to use the tire when i know the price last time.
Actually i used Achilles tire for my Jazz for 3 years already. yes, it is slight noisy than others tire but gain good grip for wet and dry condition. it is really "durable" & economic as i'm frequent highway user. this is my 1st try on my udm :)
Hi Kee, recently my driver power door start to have problem which is the squeeze sound. I would like to ask whether your window's motor is same meaning as window lifter? i was quote for 600 per side.
I am surprise for Achilles tire due to many of my gen 8 Honda accord club member start to use this tires. I am wondering whether i should change this after my goodyear run out. Achilles(cheaper) or Michelin PS3(Performance but expensive), since i am happy with my newly change PS3 in my e46。 Any advice from you will be gladly appreciate.
Yes. it is the same (No.7). RM400/pcs @ M Speed :)
lovingtime7;654622 said:
Ok, may i know it is made in taiwan or its original part?
i'm not sure from where it made, but not BMW orignial part i guess.
As usual most of the workshop will said it's Germany parts....but not original
Hi bros, my first maintenance of the car. 3rd day of my ride. Wanna have piece of mind so went to service it. Mileage: 69,000km (not sure real or not for a 2002 model).
Took the car to Optimum Motorworks, PJ. The damage:
Oil Filter RM38.60
Petrol Filter RM208.00
Micro Filter RM87.00
Rear Brake Pad (Textar) RM192.00
Rear Brake Sensor RM42.00
Auto Transmission Filter RM106.00
Auto Transmission Sump Gasket RM98.00
Gear Oil Level Oil Seal RM64.00
Ravenol Fully Sync 5W/40 RM230.00
Auto Transmission Fluid RM354.00
Service charges:
Inspection RM60.00
Renew Rear Brake pad RM30.00
Remove & change
auto transmission filter, sump gasket & auto
transmission fluid RM80.00
Remove & change gear level oil seal RM30.00
TOTAL damage RM1,1619.60 + RM12 service tax = RM1,631.60
There are more things spotted during the inspection like my steering rack is koyak. Price between RM1,500-2000.
My cockpit indicator not showing - sensor problem or even motherboard. Needs time to find out.
I will leave those things until later, cant swallow too many things at one time.
Last time I changed my L front window lifter at MSpeed cost me RM400.. I doubt that this original because have small sticker with chinese character on it and not come with plastic wrap... That was my last time servicing @ Mspeed..as I am not so happy about it
Recently, I changed my R front lifter.. but this time I bought it straight from Bavarian Auto.. The original one brand BROSE cost me RM340.. and cost to install this lifter RM30..
Although I feel like this is very overpriced piece of metal and strings.. somehow I am happy because it's ORIGINAL!!!
Just bought Brose front passenger lifter for rm200 at Munich Auto Segambut. Yes,the original use this brand and in my case last for 8 1/2 years.
WATTT!!!.. only RM200!!!!!! its alot of different mann!!! I tot mine already the best price!!!! :listen:
Went to the shop with my mech,if I were to go there by myself minimum rm230 at least.
Sorry to ask bro..just want to know the is price one pair or one item.thanks for the reply
Just grab 2 bottles of Castrol Edge Fully Syntertic 0-40w for my next interval service from Tesco Extra Seremban with RM149/bottle for 4ltr pack. It seem the promotion are coming back on Tesco here, the normal selling price was RM199/bottle.
herbert;668858 said:
Alex,
Any reason why you are using 0-40w?
Bro,
In fact this is my second time of using this Brand and grade of oil for my engine. I did observe after running with this oil for 5k km and the deep stick still show me my engine oil are clean and clear and not like normally it will turned to very dark brown in color. So i presume this oil are good for my engine and it dose not create so much of friction on the piston and so for the wear and tear to my engine. Between of that the price of RM149/4ltr on grade Fully Synthetic is consider cheap to me and this Castrol brand also was the engine oil which recommanded by our UDM.
B33mEr;668859 said:
Thanks for sharing bro ... Hope you don't mind i'll add your info into the oil promotion thread
http://www.bmwclubmalaysia.com/foru...e-Discounts-and-Promotions-Information-Thread!!!
Bro it is ok, in fact i suppose to post this info on your thread. Sorry i just didn't notice that you have started this promotion thread. Thanks and cheers..
Just completed DIY of oil and coolant leakage,
1. Connection cylinder hear - RM 60
2. Timing chain tensioner - RM 150
3. Gasket steel timing case - RM 80
4. Profile gasket timming case - RM 35
5. Coolant, 1.5 ltr - RM 45
6. Mounting plate exp tank - RM 220
7. Rocker cover gasket - RM 60
8. Expan. tank thermostat - RM 204
9. Water valve - RM 330
10.Expan. Tank - RM 200
