E46 Part and Service Cost II
Alex5522;636265 said:
Restore my roof lining + all pillars 2 days ago at Ah Kit Shop RM400 :top:
Same material as factory? I need to get mine done, it's good price.
My first visit at WP Auto pandan indah . fast service rendered less then 1 hour . thank's for the info guys ..
water pump - rm368
fan belt - rm68
coolant - rm38
workmanship - rm80
total : rm 554.00
For me it was almost 95% same as factory made, the only the wording of AIR BAG on A Pillar will be gone.
Rgd the price, it was very reasonable for me but im not sure to u.
Alex5522;636267 said:
What brand was your (Front Rotor (Pair) : RM 110x 2) ? it's seem quit cheap the price.
Its OEM TRW ... a friend in KK says its much better than lemfroder since too many immitation so at least you the equal with not much branding... as for the shipping its because its about RM16/KG by air so 10 kgs = RM160... saved a lot compared to local diskbrake cost about RM 300++ lowest can get for TRW here in EM is RM 280 per piece...
It seem the seller making their profit from the shipping charge to u. I change mine last Nov bought from BA brand TRW too $120/pc parts no 34111164199.
I guess so well... minus the labour i think so far i safe thousands so far :p
Did my major repairs at M Speed recently
Engine top overhaul RM3500
Rowe 5w30 engine oil and filter RM270
Time sensor RM280
Engine oil cooler RM580
Gear oil cooler RM580
Bosch Ignition coil 4pc RM600
Fuel pump RM520
Boge absorbers 4pc RM1700
Front head lamp cover 2pc RM440
Original front chrome grille 2pc RM400
Total RM8740
MPS Auto Sunway
Michelin Pilot Sport 3 205/55 ZR16 4pc RM1916
Alignment, wheel balancing and camber RM 125
Total RM2057
Bavarian Auto
Rear trunk brake light housing(rear fog light) 2pc RM350
DIY installation FOC
Grand total RM11,147:13::banghead::43:
Time sensor RM280
Fuel pump RM520
Total RM8740
MPS Auto Sunway
Total RM2057
Bavarian Auto
Bro..what's wrong with your engine?...whoa RM 11,147.13 could be used for downpayment of another ride...
Well, as my car is maintained by AB, losta oil sludge/carbon clogged, consuming engine oil like no tomorrow, emitting white smoke & lost of power. I've been driving it for about a week after the repairs, hopefully it solves all the problems. I'm still monitoring the condition of the car, will send back to M Speed for leaking checks in 2 weeks time (due to overhaul works).
I think its normal. what ride can get for 11k downpayment?
Time sensor RM280
Fuel pump RM520
Total RM8740
MPS Auto Sunway
Total RM2057
Bavarian Auto
There is a lot of item which is expansive and not so urgent to change here... but well if you have $$$ why not :p
That Oil cooler really expensive...Top overhaul cheap...I was quoted 4.5k by MSpeed before.....I did it somewhere else for 6k...
For 6k you can get a jap recond engine, that was what MSpeed told me before I decided to go for overhaul
What to do...you have chosen a Germany chick with Green or blue eyes instead of a Japanese Big black eyes...
Finally, my expected repairs are here, one day after 4k kms clocks i realised my tiled floors are filled with a puddle of oil, not huge but enough to freak a normal turbo users out.
1st step check my black oil stix - notice a slight drop about 50mm drop, oh well still well above safety limit.
Send it to Performance Werks usj1 (Hsien) recommended by a friend, good service and diagnosis, quote you before they start work, very reasonably price. I got quoted for triple the price from LKS Jln ipoh.
They jacked the car up, looks around and found there was a lot of GLUE, do not know why, but my heart told me that the owner glued it before he sell to reduce oil leaks. Ai how shitty is that. Glued my oil pan glued my vacuum pump tight.
Full service: RM890
ATF Vaico 6L manual flushed - 250
ATF filter with gasket- 165
Fully Syn Eneos - 195
BMW oil filter - 45
Brembo brakes w/ skim - 170+70
Damages or wear/tear:
Oil pan gasket - 110
Vacuum pump oring - 30
Valve cover - 280
Sensor o'ring - 72/4
Dip stick oring - 10
Lower arm bush - 270/2
Pump cost - 40
absorber bust - 76
wheel/align - 50
eibach change coil -100
Total damage -2500
Thank Kew bimmer!
10/1/2011@Tyre shop near TESCO Puchong
Tyre balancing and alignment (4 wheels) = RM25
Total = RM25
23/2/2011@M Speed, USJ
Front brake pad (2 pcs) = RM160
Engine mounting (2 pcs) = RM400
Absorber F&R (4 pcs) = RM1700
Front lower arm c/w bush (2 pcs) = RM1450
Link rod (1 pcs) = RM120
Discount = RM30
Total = RM3800:banghead:
24/2/2011@M Speed, USJ
Rear spring pad (4 pcs) = RM180
Accelerator cable (1 pcs) = RM100
Labor to repair abnormal screw sound = RM20
Total = RM325
9/3/2011@M Speed, USJ
Normal services
7L ROWE engine oil
Oil filter
Labour
Total = RM400
23/6/2011@M Speed, USJ
Normal services
7L ROWE engine oil
Oil filter
Labour
Total = RM400
Replace driver side power window's motor c/w mounting
Labour
Total = RM400
Total = RM800
5/7/2011@Tai Hin Workshop, Kuala Kangsar
**Breakdown at highway (230.9km) due to belting gone.
Fan belts (2 pcs, 1 long & 1 short) = RM170
Modified used pulley (1 pcs) = RM90
Labour = RM250
Towing = RM180
Discount = -RM90
**Any comment? Consider kena potong?
Total = RM600
As I did an top overhaul about a month ago at MSpeed, went back there after 2000KM for follow up check and did some repairs as lot of noise coming from the undercarriage.
Rear wheel bearing RM350
Rear control arm bushings RM480
Front wheel bearing RM500
Front control arm & bushings 350
Update DME & EMG/SMG software RM200
Bosch Aero-Twin wiper blades RM120
Total RM2000
Will update this post to see if the DME, EMG/SMG software update improves efficiency & performance.
10/1/2011@PJT Tyre, Puchong
Total = RM25
Discount = RM30
PJT Tyre, Puchong
Total = RM325
Normal services
7L ROWE engine oil
Oil filter
Labour
Total = RM400
Normal services
7L ROWE engine oil
Oil filter
Labour
Total = RM400
Labour
Total = RM400
Total = RM800
**Breakdown at highway (230.9km) due to belting gone**
Labour = RM250
Towing = RM180
Discount = -RM90
Total = RM600
12/7/2011@Hin Leong Tyre, Klang
Achilles 235/35/19 (2 pcs) = RM800
Rotate existing tyre (2 pcs) = FOC
Balancing + Alignment = RM50
Alignment rear chamber = RM50
Total = RM900
