E46 Part and Service Cost II
keong;580308 said:
bro cesna,
just 2 weeks already spend 1600 plus....? u buy ur car from dealer?
Bought it direct from owner. dont know what to say already bro. but i think the expansion tank is a must to change since the last by owner changed it in 2005.
Just serviced the E46 325i M54, mileage@120k
M Performance Auto Sdn Bhd - Tmn Mayang Industrial Park, PJ
Mobil 1 Engine Oil 5-50W 6.5LxRM52 = RM338.00
Oil Filter (Ori BMW) = RM40.00
Radiator Breathing Screw = RM10.00
Spark Plugs (Bosch Long Life) RM35x6 = RM210.00
Labour to engine oil service, replace spark plugs, reset engine oil service light = RM70.00
Grand Total = RM668.00
Any feedback? Appreciate it.
I bought Bosch Platinum spark plugs from Bavarian Auto for only RM20 each.(the last set lasted 80k km)
Other items changed: micro filter (carbon)=RM75, brake pads (ori BMW)=RM230, brake sensor=RM28, oil filter =RM25, oil filter cap =RM110, Syntium 800 5l=sendiri beli
Labour for everything=RM100 @ Carpro One Selayang
E46 318i N42
i just replace window regulator - driver side .. RM400+. Labour around RM60+. I think abit expensive. Shop at Zender (Segambut). Hope that helps. They quote me lower arm .. pair @ RM1800 including labour. Is this consider cheap ? Sound like expensive also.
325 SMG
325 SMG
The lower arm quoted was Ori or Oem bro ?
325 SMG
A bit expensive for the window regulator ... M-Speed quoted me RM400 inclusive labour for front window regulator.
Not sure about the control arm though ...
yes. just realize the regulator is abit expensive. just to share the info for the benefit of other forumer :).
If i'm not mistaken the shop said original .. is it cheap ? I'm still looking around for best price. Need to change both lower arms.
midship;585750 said:
Whats the difference between Ori vs OEM?
Same item, one with BMW logo and one is not. Manufactured by the same company. Thats what I understand.
An original equipment manufacturer, or OEM, manufactures products or components that are purchased by a company and retailed under the purchasing company's brand name.[1][2][3][4][5] OEM refers to the company that originally manufactured the product.
When referring to automotive parts, OEM designates a replacement part made by the manufacturer of the original part.[6]
Contents
[hide]
Is very expensive oh..$1800(what's model of your udm) i just changed mine 2-3 months ago $325/pc (OEM)
btw mine was E46 320i
Fuel pump
Yesterday, DIY fuel pump replacement.
a) Fuel pump - RM 450
b) Fuel filter - RM 80
Yes .. i think should be around RM1K only for both side with labour. Mine is 325 SMG.
SMG cars comes with M-Sport suspension as standard (for CKD version anyways :D) hence the control arms will be more expensive
yes. dat is true coz the shop showed me the m-sport suspension when they quoted me the price.
My turn..baby just came out of hospital. Big bill. Here goes:
Chassis Stuffs:
1. Front Absorber (Boge) (R/L) - RM 395 each
2. Front absorber damper (R/L) - RM 38 each
3. Front absorber mounting (R/L) RM 98 each
4. Rear absorber (Boge) (R/L) - RM 215 each
5. Rear absorber damper (R/L) - RM 38 each
6. Rear absorber mounting (R/L) RM 59 each
7. Steering bellow (R/L) - RM 58 each
8. Front lower arm (OEM) (R/L) - RM 445 each
9. Front lower arm bush (R/L) - RM 340
10. Labour - RM 200
11. Alignment - RM 40
12. Front brake disc (OEM) (R/L) - RM 350 pair
13. Front brake pads (OEMM) (R/L) - RM 170 set
14. Brake sensor - RM 38
15 Labour - RM 60
Cooling Stuff:
16. Radiator breather screw - RM 10
17. Radiator spare tank (expansion tank) - RM 215
18. Radiator cap - RM 53
19. Radiator spare tank mtg part (inlet for radiator) - RM 225
20. Service radiator, radiator gasket and top casing - RM 300
21. Auto oil cooler seal ring x 2 - RM 12 each
22. Oil cooler pipe seal ring x 2 - RM 11 each
23. Thermostat seal ring - RM 26
24. Labour - RM 130
Engine Stuff (leak):
25. Power steering hose - RM 125
26. Power steering oil - RM 28
27. Valve cover gasket -RM RM 58
28. Engine oil sump gasket -RM 98
29. Oil filter housing gasket - RM 18
30. Oil filter housing seal ring - RM 10
31. Timing oil seal - RM 48
32. Timing cover gasket seal - RM 45
33. Timing cover gasket - RM 85
34. Engine oil top up - RM 27
35 Expand rivet (what's this) - RM 5
36. Hose clips 12x20 - RM RM 8
37. Labour - RM 220
Total - RM 5658 :roll:
Early Christmas present for my newly acquired baby....first drive...everything feels much tighter...some sound coming from the back...will send it back to check. Now its a UDM..looking out for lowered springs..either Eibach, H&R or Tein. Still deciding. Comment away...
Oh yeah, did tinting also - RM 500.
guyfriendx;590705 said:
lower arm bush (M3) - RM85 per piece. change both side.
Did you buy just the bushings or does it come with the housing/bracket? If bushings only where did you had the bushings pressed?
