E46 Part and Service Cost II
FazrulGTi;557187 said:
The car just came out from Customs last week. Bring it to Milan Motor at Tmn Sg Besi doing a check up today.
1. 2pcs control arm bushing - Rm380
2. Oil level sensor - Rm240
Labour Rm80
Total cost Rm700.
Next change might be:
Expansion tank + labour - Rm550
Radiator - Rm4000 :banghead:
Aku baru takar radiator before raya, cost me only RM 850 include labour (radiator only lah)
ytdy damanged 1550
1 pair disc brake(F) -300
1 pair brake pad(F)-160
water hose 386-164
water hose 398-40
pipe connector 808-48
water hose-110
water hose-120
expansion tank-210
themostat-220
labour-80
coolant-free
total 1550 after discount.
IM scared.................. my car in garage now... later will go to collect... how much need to pay...........
My car at workshop now for TOP overhaul cause oil leaking and spark plug jammed. Better becareful when sent your car for service. as afraid the foreman tight the plug until jammed. And at the same time Oil Cooler kaput and water already mixed with ATF Oil become Teh Ais color. Total cost not sure yet. Syntom for Oil Cooler issue is the display for Gear just on and off..sometime on sometimes just gone...lastly will get Save mode and Transmission error. that's mean S and the Transmission Icon.
Anyone can recommend me for this : I need to change lower arm, but it is the teflon/silicon tpye already, not the original. How much will it cost ?
03-11-2010
Head Gasket – 1pc 280
Top Set Gasket – 1 set 640
Upper Timing Chain 135
Upper Timing Guide Rail 98
Upper Timing Chain Tensioner 175
Water Hose 107
Engine Thermostat 185
Water Tank Thermostat 198
Water Tank 215
Valve Pipe 128
Pressure Regulating Valve 237
Valve Pipe 127
Valve Pipe 130
Brake Valve Hose 198
Throttle Body Air Hose 98
Throttle Body Air Hose 115
Exhaust Manifold Gasket – 2 pcs 330
Water Hose 98
Washer (2pcs) 192
Washer (2pcs) 98
Fuel Pump 480
Fuel Pump O Ring 48
hose clip (6pcs) 24
Axle Bush Big 135
Axle Bush Small 128
Coolant 30
Engine Oil Full Syn – 8l 408
Oil Filter BMW 68
Oil Filter Housing Gasket 68
Oil Filter Hosing Machine Screw 96
Oil Pressure Switch 78
Fan Belt Bearing 87
O Ring 10
Rean Antirollbar Bush x 2 50
Cyinder Head 4800
Rubber Air Hose 45
Labour Charge 1300
TOTAL 11,639
Cloudbuster,
From your list above, I observed you have been over-charged for many parts.
herbert;578563 said:
Cloudbuster,
:burnout: Yeah, you are right, Herbet. I know certain parts charged by my mech are more expensive than others. Just want the convenience of getting them done all at once at the same place. Don't really mind the extra costs incurred. Plus, alot of those parts were replaced upon my request. Even decided to use a new cylinder head (specifically for an E60) instead of a used one from a potong kereta.
Initially, was thinking of going to get some done at Albert's, but apparently he moved to another location in Pandan Mewah and I couldn't find the new place.
hi bro..whats your car year born ? are you 1st owner or 2nd? sounds scarryy:eek::eek:
cloudbuster;578554 said:
03-11-2010
Water Hose 107
Water Tank 215
Valve Pipe 128
Valve Pipe 127
Valve Pipe 130
Water Hose 98
Washer (2pcs) 192
Washer (2pcs) 98
Fuel Pump 480
Fuel Pump O Ring 48
hose clip (6pcs) 24
Axle Bush Big 135
Axle Bush Small 128
Coolant 30
Oil Filter BMW 68
Fan Belt Bearing 87
O Ring 10
Cyinder Head 4800
Rubber Air Hose 45
Labour Charge 1300
TOTAL 11,639
Hahaa.. don't be scared. Mine's an old, consistently abused 2001 325. Most of the stuff replaced are not a 'must' but more just for a preventive maintenance basis only. I normally do that for most of my old ladies when the time comes (if I can afford it). Plus, it's high time for me to re-vitalize the old lady. Actually, the price charged by my mech is 20-40% higher than norm, and I'm ok with it due to their 'acceptable' service and its near where I stay.
Anyway, the good old UDM feel is definitely back now.
Its really alot. I remember changing the oil filter gasket for only RM38 at an authorized dealer...RM68 is wel beyond. You sure u want to continue burning your pocket unnecessarily? Perhaps there's alternative near where you stay?
I'm staying in Cheras. Any gud recommendations for alternative choices?
bmw7833;578595 said:
Anyone can post up Albert' new workshop location?
Albert's new workshop address:-
WP AUTO SERVICE
No 41, Jalan 3/5,
Pandan Mewah Industrial Park
68000 Ampang
Selangor
Tel: (03) 4295-5755
Mobile: (012) 201-7792
Just service my car, any comment?
Engine oil*7x51 = 357
Oil filter = 38
boot kit= 76
Front brake pad= 311
Sump gasket = 56
fl strainer= 52
harness gear box = 950
ATF = 8x59= 472
labour for diagnosis= 50
labour for harness = 150
labour for brake pad = 80
labour for oil change = 50
labour for ATF = 80
Damage rm2.6k with discount
I think herbert just answered ur question...=)
Yeah, I've to Albert's old place once, and he's good. However, it's in Ampang which is quite far from my home (my missus would nag about going to a place further than necessary as she is driving an e46 too). If there is an alternative in Cheras itself, it'll be excellent.
After 2 weeks own E46 320i, few things that i have changed. i'm still looking for reasonable and reliable workshop/mechanics
Mech 1 :
expansion tank = 235
thermostat = 250
coolent = 60
air filter = 55
radiator cap = 55
labour = 95
total = RM 750
M-speed
2 x engine mounting = 380
lower arm FL = 500
Steering boot cover = 75
labour = 50
Discount =
total = RM 975
bro cesna,
just 2 weeks already spend 1600 plus....? u buy ur car from dealer?
