E46 Part and Service Cost II
SBB;535841 said:
Hi,
I see that it is so much cheaper using used AC compressor. Normal price (new) RM1,600 i guess.
Just wanna to know, where to get it and can the dealer gives sort of guarantee that it is useable.... tak bocor or what so ever? probably 1 week warantty pun sudah cukup to test....
Tx
I got 1 unit ori BMW fully reconditioned from my E39 which I think can be used on e46 but need to confirm wt yr mech. RM600. pls refer
http://www.bmwclubmalaysia.com/forums/showthread.php?t=33186
hi all,
just doin1st service after bought my e46 325 2 month ago.doing at m technic tampoi.
1. castrol edge fully syntetic 8 litre -rm390
2. oil filter- rm40
3. change 1 ignition coil -rm 170
4. diagnose/ labour - rm140
dont know cheap or not... any idea
JLV1717;539048 said:
hi all,
2. oil filter- rm40
If u ask me I 'll say expensive. The oil filter ori? RM140 for labor & diagnostic???
hi all,
2. oil filter- rm40
normally labour charge around rm20-30 only
i went through quite a lot or rather 3/4 of the pages here in part 2 n part 1 but need some information.
whats the price for a major service for e46 (1.9 and 2.0)?
bro, this thread is for listing your expenses incurred for service and maintainance. :rolleyes:
Major overhaul is not servicing.. :listen:
StopMe_;541707 said:
hmmm... looks like std pricing..:top: similar cost
StopMe_;538670 said:
Latest 'damage'... got weird sound from the front tire... found out the right lower arm ball joints loose..
Now changing
1 set lower arm left-right RM600x2
1 set lower arm bush left-right RM350
labor RM80
TOTAL RM1630
Got gearbox leaking... I wonder how much the cost? Will claim warranty instead for this damage
My price RM350 is for left and right side. Your also same?
why you need to change the lower arm as well?
Correct me pls if i'm wrong :
The ball joint was fix tgter wiv the lower arm, so must change the whole lower arm. Only the bush u can change seperatly. I just bought 1pc of (FL) lower arm cost me RM325 And 2pcs of bush RM85/pc for my E46
Normal service for E46 1.9
1. 4 L of BMW LL oil + filter + labour RM250
2. Rear wheel bearing, 1 pr + labour, RM350
Regards
Can you PM me where you bought the lower arm and bush? I think it's time for me to change mine as well. tks
The ball joint already loose - got weird sound... now no more :top:
Pls check your pm. Alrdy pm u
Can you let us know where did u get your Lower arm... MSPEED quote me RM1k each...!!! Is it original or OEM ???
Guys,
Do u know how much is the total cost if I want to change these?
1. radiator
2. expansion tank
3. thermostat
4. water pump
5. all water hose.
for E46 2.0 2003
affan66;363836 said:
Just spent a big chunk of money on my newly acquired 320 2.2.
Most are replaced due to "insurance" rather than need replacement.
Air filter RM68
AC filter RM135
Water pump (ori) RM495
Coolant tank RM265
Coolant tank thermostat RM245
Thermostat housing RM195
Gear box oil (ori) RM680 (10 liters)
Gear box filter and gasket RM210
Injector cleaner RM42
Windscreen cleaner RM8 (arggghhh!!!)
Coolant Rm28
Fuel filter RM185
Rear axle oil RM48
Fuel hose RM9 (6 pcs)
Hose clip RM24 (6 pcs)
Vacuum hose RM6 (4 inches)
Key case RM116 (2 pcs)
Update EGS, key reset, convenience features re-programming RM280
Labour RM280.
Total RM3319.
*pengsan*
stopme_ pls to affan posting.
