E46 n42
satiash04
hi,i have already paid deposite for an e46 year 01/02 (face lift model). its a recond model. I heard from few people saying that e46 N42 engines are problematic. need u guys advise on this issue and what are the precautions that i should take before buying the car? also please advise on the maintainance cost and consumption of the car?thanks.
Mate, I am an e-46 fanatic and its pure joy driving this car. The car zips through traffic easily, superb fuel consumption, sporty in its looks...ya da ya da...
Nevertheless, N42 engine is indeed a lil bit of 'princess' but will be ok if you take good care of it.
Servicing/Oil change is best done at every interval of 6000km-10000km instead of the regular 15-20km interval.
Average cost of oil change & general servicing is not expensive. Range from Rm 250-400. The usual Jap cars are charging Rm150-200 on normal servicing at every 5k interval.
The only precaution you need is on engine leakages, radiator leakage, gearbox. Get an experienced mechanic to check on the car b4 you buy it. (Read all about it in our forum on workshop & servicing thread).
Enjoy your ride!:top:
Hi guys...
how to differentiate between N42 and M43... perhaps someone can post a pictures... coz cannot find it in the web....
Dude,
M43 u can find in E36 years 95 till 99, looks the same for e46 as well.
So, the other is definitely N42.
rgds
Typically copied and paste from Wikipedia.
M42
The BMW M42 is a DOHC 16-valve I4 piston engine first built for the E30 318is and 318i 1991 year model. The engine block is based on the BMW M40, used on the 318i, but had distinctive features such as double overhead cams driven by a timing chain, hydraulic valve lifters, and an increased 10:1 compression ratio. The USA version of the 1991 318i only came with the M42 engine.
Profile gaskets on M42s built before 1993 are known to fail prematurely.
Displacement for the M42B18 was 1.8 L (1796 cc); cylinder bore was 84 mm; and stroke was 81 mm. E30 318iS, 318i (in the U.S.; European versions of the 318i were fitted with the M40 engine), and early E36 318iS/318ti (prior to 1992) models were fitted with versions producing 100 kW (134 hp) and 172 N·m (127 ft·lbf). Later, change in the overhead cam design helped to achieve 103 kW (138 hp) and 175 N·m (129 ft·lbf) coping with the increased weight of the E36 models. The engine uses Bosch M1.7 fuel injection.
The M42 is a popular engine swap for 2002s and E21s. It is a relatively inexpensive swap, and produces more usable power than the M10s, while still being lighter, plus utilizing modern EFI and direct-ignition and a much improved valvetrain.
Further, the long-stroke forged crankshaft from the M47 motor coupled with an overbore of +2 mm will make for a 2.1 L Stroker M42. The 86 mm pistons from a European 3.0 L S50 will produce a high compression, stroker M42 when coupled with the M47 crank. The addition of a MAF conversion from an M50 engine and properly setup cams, valvetrain, and tuning will yield potent output from the "lowly" M42.
Applications:
* 1989–1991 E30 318iS/U.S. model 318i
* 1992–1996 E36 318i/318iS/318ti
* 1993–1995 E36 318i — (Produced in South Africa for South African market only.)
M43
The BMW M43 is a straight-4 piston engine. Displacement ranges from 1600 cc to 2000 cc.
The engine was built solely on Assembly Line 2 at Steyr, and was the successor to the M40.
It features ICIM (Individual Control Intake Manifold) and 2-valve technology. The ICIM optimizes the torque curve and is also aided by anti-knock control. Like the 16-valve, 4-cylinder M42 engine and the 6 and 8-cylinder engines, stationary high-voltage distribution is also used on the M43. The M40's timing belt was replaced by a chain as the high engine bay temperatures reduced the lifespan of the belt. Engine ratings were slightly raised while exhaust levels and fuel efficiency were significantly improved.
A further technical revision occurred in 1998. The displacement capacity was increased to 1.9 litres, resulting in improved torque of 180 Nm at 3900 rpm. The intake manifold was also constructed of plastic for added weight savings.
From 1993 to 2001 a total of 1,204,734 units came off the production line, making this the Steyr plant's highest-production engine
The 1.9 L (1895cc) M43B19 was the largest M43 engine. It produced 87 kW (118 hp) and 180 N·m (133 ft·lbf) or 77 kW (105 hp) and 165 N·m (122 ft·lbf). It used BMW BMS 46 fuel injection.
It's also known as M43 TÜ engine. It had twin-balancing shafts.
Applications:
* 87 kW (118 hp) and 180 N·m (133 ft·lbf)
o 1998-2001 E46 318i/318Ci
o 2001-2003 BMW E36 Z3 1.9
* 77 kW (105 hp) and 165 N·m (122 ft·lbf)
o 1999-2000 E36 316i compact
o 1998-2001 E46 316i
ok
from my experience driving an e46 ci N46 is ok..not a BAD AT ALL as u read in the forum...fuel consumption is good. under power? pickup ok bro..mine is manual..u only can feel the difference on top performance compared to 6 cyl.Top speed mine is 215km smooth.. Maintenance is cheap..just keep u servicing on right time. If u want more..just upgrade the performance..mine after build custom extractor, full piping, sprint booster, CF air intake, remap ECU, machine disc brake, adjustable absober,high cam, the feels is totally dif. Yes the 6cyl is good..i totally agree based on driving experience on 325 and 328i..but please take note don't play2 with 4 cyl also. The 320si WTCC are 4 cyl not 6 cyl..for touring Bmw engineering only focus on
M3 version and 320si version only...which means that the 4 cyl is not a bad at all...as long as the car are wearing UDM machine there are some speciality that u can't guest what the engine can do....if u want more power then go for the REAL POWER loh get an M3:top:....no headache
Guys... where is the engine number located?...I only can find the chasis number....:listen:
