E46 Air con problem
Very useful info, thanks to everyone who contributed in this thread. Now I roughly know why changing from 27C to 16C doesn't make any difference on my ride!
i ve d problem also.thought of going to naidu in kl.where did u do in ipoh coz i from ipoh also.
no nid go naidu so far la....ipoh there is 1 workshop...which i alwiz go to wen a/c is concern...if u know tuck kee in pasir pinji....is just opposit tht row of shop lot..there is big denso sign...thts the shop...same price as naidu...also take just 1 day to fix...workmanship...good..so far no scratch on my dashboard or anything...
braine5;306932 said:
hello to every senior member here,
i would to seek for ur help,
currently, my car E46 325 air con got problem here,
the driver side and one of the center side coming out hot air while the other working very well..
so...when driving that time, i gotta shut off the air for the driver seat ( hot la)
i have been one nearby workshop for this problem
but mechanic said should be leaking ,he need about 2k plus for fixing and changing the cooling coil...and he ask me to take out the heater valve as well
so he ask me leave the car for few days..
but i reject alreadi..coz need to use the car..
somemore not very confident with him
so..have any brother encounter this problem
dun take out the heater, if not you a/c sure cant cool at nite, if change "or" cooling coil , dryer , valve . gas ,and all labour chage is nearly rm 1550. in bercham there
i need help urgently... someone please help as the weather is very hot now a days and i'm not able to take it with the heat
Bro you're seeking help without explaining the nature of your problem.
3 Simple Check list
#1 Ambient Temperature not lost? ( Press "BC" left hand signal button) ---> If Temperature display is 50 / -14 degrees celcius its gone
Soulution: Buy new one and ur aircond will be back to normal
#2 Check Aircond gas/system
#3 Tint your car :p
If you had bothered to do a search in the forum, everyone goes to Naidu to get their aircond problems fixed. So - go to Naidu.
Salut
thanks xcrave for your suggestion
sir seewai and sir solo..i have mentioned that my prob was the same and my question was whether there was a shop in klang... of course if naidu was in klang i would have went there already... and before you say naidu is in jalan ipoh...i know...
anyway... thanks for all your help
Bro, Naidu is near EPF Jalan Gasing. Actually I found out there's no problem with my a/c.
Oh sorry for salah tembak you. My sincerest apologies. Looks like since no one has given any info about an aircond specialist in Klang, you may have to look for Naidu.
Salut and sorry
no prob... all good... at least you saw my shout for help... :D
setting up an appointment in a place in klang to fix it...
Just had my heater valve replaced, freaking expensive at its the same one used in the E46 2.0 valvetronic.
One of the symptoms is the fuse (no.62) kept getting blown. But now discovered the motorised flap may not be working as well.
@yen187
Bro so what was the problem? it would be great to know...
BTW ALBundy, what was the cost :p
