e39 year 2000 power - can I increase it
publicbus
Dear all sifus,Not sure whether this has been mentioned in this forum, Tried searching but could not find any.How do I increase the power of my e39 year 2000?Cheers
publicbus said:
Dear all sifus,
Cheers
Hi bro,
If yours is year 2000 M52TU, i have it, but it is not cheap. PM u my contact to discuss.
Cheersss
Try stroking the engine. Currently my mechanic is stroking an e60 M54b22 to 2.7l.
Dave - will call you soon.
tamade7 - what is stroking. How long will it take?
Cheers
dave said:
Hi bro,
Cheersss
dave - not sure whether mine is TU or not. Checked at REALOEM and this is the info :
P E39 Lim 523i M52 MYS 20000500 R A
Cheers
Stroking means to increase the stroke of the engine and thus effectively increasing the capacity. Your enigne has a 84mm bore, 75mm stroke where you can increase your stroke to 89.6mm and it will become a 3.0l engine. You can also increase the bore but it requires more work because the block needs to re-sleeve. To get everything done it takes about 10 working days.
For less than RM 3k
publicbus said:
Dear all sifus,
Cheers
Wanna try this...........
All for about RM 3000! But do not expect it to be like turbo-charged but improve overall torque & bhp.
check it out here
http://www.eurocarmotorsport.com/frame.htm
Bro,larger the CC ,then the crank and cam sharf need to upgrade or not ? thanks
Like what you said, then can install the high angle cam,sure increase the hp and torque! thanks
