Volvos525i
Club guest
- Apr 8, 2013
- 2,640
theblackbeast;826730 said:Issue not solved yet bro.......beast is taking a break away from the busy highway. Just checked your PM....thanks!
Hope you can solved the prob...
theblackbeast;831589 said:After more than a month, after exploring with various mechanics / workshops finally I see light :top:
events which turned my ride up side down ............
So far what I read from the net is "pusher fan will kick start when a/c clutch engages.....but did not find anything pointing to failure of a/c clutch = non functional pusher fan. I could be wrong. So let's see what happend by next week. Missing my black beast!
- a/c compressor died because pusher fan failed
- changed compressor and pusher fan - happy with cool air for 3 months
- after one week changing the above , noticed the pusher fan was completely at high speed even on the very first start in the morning
- took back to TnT Sunway but unfortunately by the time I reached there - natural wind cooled off the condenser and pusher fan speed was low
- having to take Tan's word that all if fine - a/c broke down one fine morning
- Naidu did first diagnosis and said all sensors ok, suggested could be the control panel.
- One good soul from this forum swapped his control panel with mine still no luck - my unit worked well on his car.
- Brought to Optimum, Jason advised he does not do a/c issues but forwarded me to another guy @ TTDI. This person ripped my control panel front face incorrectly and said it was already like that .....:stupid:I was so pissed and drove home.:102:
- Siva@e39 help to intro Brian (TTDI). He forward me to another place in Kota Damansara, where his comp was detecting evaporator sensor + pressure switch fault pusher fan fault = RM380
- Changed evaporator sensor + pressure switch fault = compressor clutch did not engage either. All other fuses - relays are ok.
- He plugged the comp once more and this time it says fault with climate control panel. Car was here for 1 week now.
- Waited there for 5 hours and the chop shop guy brought a faulty unit..........what a day!
- Contacted back the good soul from this forum - swapped back the control panel unit from his car....praying real hard.....:63:..but did not work either.....my unit works in his car.
- Did more research on the net and could not find why nothing is working.....
- Finally I found the long lost number - ex Auto Bavarian M5 trained who now runs his own workshop
- He intro me to a wire man. After one week I received a call from him..He cleared the pusher fan error - walla ........clutch engaged but not for long.
- Went around today looking for 3pin pusher fan = RM380
- Plugged in and the moment I was waiting for ......coooolllll air ....aaaaaaaaaaaa........:cheers:
- However we noticed the symptom again....with first cold start the fan is spinning ready for take off......
- He told me if the fan continues to function like this, it will die soon = failing a/c compressor / clutch
- Left it there for him to check on any other sensor which did not trigger fault code before the working fan was installed, just incase the comp was not able to pick it up earlier as there might not be signal flow.
Anyone knows if comp diagnosis would be able to give ECU error code?
and the fairy tale continues ................:burnout:
Thank you Bro Siva@E39 / 525i & Volvo525 for all your help and guidance!!
wingzee;831590 said:Bolded part. Care to share which shop is this to educate others?
DR.TS;831596 said:Hi blackbeast..i got experienced something like u on my E38 728i double vanos.but once i change compressor from chop shop all problem settle and air cond cold again.at the compressor itself got pressure sensor.if the compressor weak of compression cooling fan and expansion valve not working... I just share my experince i not sure it can work on yr vehicle or not...
theblackbeast;831879 said:Today the issue is FIXED, in bold below
..but did not work either.....my unit works in his car.![]()
Brought my baby home at last .......... :beer:
- After reading the forum Friday night on pusher fan immediate high speed on cold start - it was pointing to temperature sensor.
- Saturday morning went to BA Subang got one unit = RM53
- Went to the workshop , the BOSS man said got other cars to do.
- Eager to get my baby home, I swapped the unit myself and plugged in the pusher fan...speed was back to normal.
Will need to give her a good SPA treatment after close to 2 months in various workshops.
tweiboon;831903 said:Where is the temperature sensor located ?
Bmmad318i;832249 said:Radiator outlet temp sensor???
theblackbeast;832337 said:Yup you are correct, it's located next to the radiator coolant tank.
Volvos525i;832340 said:So bro everything smooth now right...
theblackbeast;832854 said:and cooler ...aaaaaaaaaaaaaa
volks2;835469 said:just bought a 520i recently, the air-cond got some problem? the outlet facing the driver got cool air, but the outlet at the front and back passengers only hot air..may i know what is the problem? Any air-cond shop recommend? I'm in KL.
