E36 M43 whole body shaking
brando
Dear Master & Sifu,Good day,Would like to hear you guys regarding above..fyi it only happen once i start the engine..not at all the time also not in the morning but most of time after the engine off for 1-3 hours..the whole body was shaking felt like there is something wrong with the engine timing (low timing),tuning or else i don't kno & when i press the fuel it will suddenly off..when it hppen i need to turn off the engine & start it again then it back to normal..some more most of time the engine will start after 3 second..mean that not like normal car which automaticly start once u turn the key on. i belive that these things also will effect my bttery & starter usage (shortern lifespan) due to need to be start twice.Appreciate if you guys can share your expirience.
check your spark plugs first lah.
Also check your HT cables is loose or not.
Sometime leakage on the HT cable due to insulation breakdown will cause this high vibration when one of the cylinders is not firing properly.
fabianyee;516142 said:
Maybe got possessed by Gintell or OSIM... :p
heh2..no need man my car tummy quite tight..it's me that need it..hah3..
Anyway u guys was so cool..TQ..TQ
Sounds like engine mounting for the vibrations, had that on mine and once i changed the mounts ..no more Osim or Ogawa. On the delayed starting , well, I get the same issue at times, yet to find out the problem.
Check the ICV hoses, if there is leak, will shake as well when idling. Else get a new AFM & O2 sensor.
