E36 at under power
ham160918
Dear All Frnd...Need advise and suggest. My UDM when started after cool engine less than 5 minute are slowly moving ( feel like under power ) even full press at the paddle. After it warm up or when engine hot roughly after 5 minute than it be a normal driving. Plse advise me ciffu. Thks:listen:
what engine ?? auto or manual ?? care to explain more about your type of e36 .. TQ
E36 auto last batch 1999 sure. What model? Please be a little bit more specific.
Bro....sorry not familiar model type..how to ensure proper model. i only understood e36 at year model 1999....
Check your road tax to see what you engine capacity is....
Bro,
I think you should know, if your UDM is 318, 320, 325, 328 or 335? :D
ham160918;575950 said:
Dear All Frnd...
Welcome to the world of UDM, sounds like a E36 318i with M43 auto gearbox. Well, to me, your problem sounds normal. I am also facing the same situation whereby my 318i M43 is very "slow" during the 1st 5 minutes. Once the engine and gearbox are warmed up properly, then it drives normally. You may want to check when was the last time you changed your engine oil and gearbox oil. Do share more experiences :wink:
Very sorry...now i understand la... Russie are right...my are E36 318i AT but not sure M42 or M43. Thks Russie for the clu and advised. Will check on it. Thks to the others too.
Change the spark plug and dont over filled your engine oil on new change. Same problem solved after new plug, new oil 5-30 Mobil 1 or Bardahl 5-30w with Bardahl 1 and also plug cable changed.
I have flushed the gearbox but the problem resolved after the above are done.
Not sure what solved the problem lorr...
Mr Geoffreylee. Noted and understood. Thks for the advise. I take all advised seriously. Thks to all guru.....
