This one dedicated to AlCasanova...Many serious installations would most likely have some form of sound dampening applied especially on the door panels. There's quite a lot of options similar to Dynamat on the market that can get the job done (and at a considerably cheaper price) but for bragging rights, none quite matches having a load of shiny Dynamat Extreme advertised on every accessible panel (even though its only for a brief moment before all panels, trims and covers go back on). So this was where it started.
Double layers on the doors given the initial plan to have speakers mounted on them. Saved a little on cost of Dynamat bcos not practical to line the steel panel immediately behind the plastic door panel unlike my previous car. And it appears that it was no longer as good an idea to have speakers on the doors. And the way the door panels and power window mechanisms are designed on the e34, wouldn't be easy getting a deep mid-woofer where I wanted it and it would be quite a challenge to get them to hit hard and play low.Same goes for the rear doors. Initially felt additional layer of Dynamat on doors had gone to waste but can't discount the feel good factor from the nice inert thud when you knuckle-rap the doors.
Shiny boot covered in Dynamat Extreme. Certain areas again double layered as panel appears more prone to vibration, e.g. spare tyre well. You get a peek on the bottom of my cherished xtant 3300c. Sad to see it go but have to make way for new amps. However I know where to go to hear her play... AlCasanova, it is not easy to handle your 15-incher... not saying you need to be gentle with the knob but try to control yourself and not push too hard... I know you like to 'feel' it but painful man! For the amp...
Another view of the boot also showing the nice and relatively compact Nakamichi changer that is an absolute delight to operate as it doesn't require use of cartridges to load discs. Unfortunately it's the model without coax digital output so can't introduce external DAC into system. Anyway, there are always alternatives...
Starting mock up for the boot install...
It gets more exciting here onwards...
