E30 can change what type of Engine??RECOMMEND PLZ
princemun
E30 can change what type of Engine?? bcoz my car under power now after change 17inch Rim... anyone can recommend???
What engine you want to put is only limited by 1. your budget, 2. your imagination and 3. your mechanic's competence, 4. your mechanic's mental health
Here is a list of engines you can consider :
1. M20 2.5
2. M42 1.8 16V
3. M50 2.5
4. M52 2.8
5. S50 3.0/3.2 from E36 M3
6. S14 from E30 M3
7. 5.7 V8 from Potiac GTO / Holden Monaro
8. Nissan SR20
1. your budget (Not Much Problem)
2. your imagination (Not Much Problem here either)
3. your mechanic's competence (The main cause of all Problems so far)
4. your mechanic's mental health (See previous answer.)
Wish I had the time to DIY :( :( :(
the problem is mine one is M40 1.8cc, can go over 2.3cc?? JPJ prove??
like S14,M20,m50,m52.......
m50 & m52 izzit E36 engine??
n who know the half cut price for SR20 or S14 E30 M3?
prince,
u want looks then now power. why not the other way round first.....1.8 with 17 in tyres will be lunch for kancils even.
If power is what u want, JPJ also can kautim one.
I recommend S50 route but then also I also a BMW V8 implant......so u can try. YES, I always advise ppl to stick to BMW engines.
Ur call.
1. M20 2.5
2. M42 1.8 16V
3. M50 2.5
4. M52 2.8
6. S14 from E30 M3
8. Nissan SR20
9. Toyota 1JZ
10. Nissan RB20/RB25
11. Honda S2000
I would echo similar sentiment to what OSflanker has mentioned. Bottom line is your budget. If low budget go for the M20B25 conversion, its pretty straight forward otherwise go for the M50 conversion!! And don't forget to upgrade your suspension and brakes as well!:) Safety is more important than anything else!
bryanlee,
pls stick to topic as ur question is irrelevant.....
giving u the benefit of doubt as newbie since u did the same in another thread "e30 maintenance", my advice is cutting in like this is considered rude.
PLUS no one will answer ur question.
Thanks.
The M42B18 1.8 16V DOHC engine is a pretty good engine in my opinion. It has more mod potential compared to the later M44B19 1.9 16V DOHC...
If you choose to take the M42 don't have to worry much about JPJ cos same cc.. Also can use back your M40 gearbox.
btw, go back to 15". E30 was not engineered to work with rims bigger than 16"
. With the 15", you get the best balance of ride, handling and comfort.
Jules, haha stick to BMW engines is good i also prefer like that :) ,M3 is my dream!! S14 or S50 also not bad. but some of japanese i saw b4 damn powerful like SR20,1JZ or S2000. SR20 half cut without installation around 4.5k to 5.5k, M42 & M50 plus installation is around 6k to 7.5k....
chriseunos;227313 said:
my advice is, change ur rims back to 15" and see, i believe 1.8 with 15" is quite ok
i know but i juz change new rim & tyre....17inch very nice :D my E30 lookmore younger.....sporty!!
AGREE!!, upgrade [COLOR=blue! important][COLOR=blue! important]suspension[/COLOR][/COLOR] and brakes as well!:) Safety is more important than anything else! hehe....duno BMW + Vtec is what feel?? :D
but,but how come my car still can wheel spin whor, summore i use 17 x 8.5" width rims hor.....:eek:
