DIY simple oil service reset.
MONTOYA
got this from another forum. tested on a local 325i. it works like a charm. so like to share with you guy. "To reset the indicator:-The car should be off-hold down the left instrument button (the trip odometer reset)-while holding the key, turn the ignition to position 1 (radio)-you will see a test menu-keep holding the button-after maybe 10 seconds, the word "reset" will appear-let go of the button and press again-THe indicator is reset!"have funs.
Tried it yesterday for my N46B20. :39: How come I cannot reset the Oil Service counter back to 20k. Anybody can help on this.
Thanks
Just follow the instruction of bro MONTOYA will do, i just did mine after clean the air mass & KN filter and it was reset.
Thanks to MONTOYA for the good info.
Sorry guys - just a question - why would you need to DIY-reset the service indicator?
Doesn't your workshop normally reset this for you after each service anyway?
Sometimes my mech also forgot to reset it, and at times when time permits some of us do the oil change DIY (along with clean MAF and K&N filter)
Did as per bro Montoya suggestion. Unfortunately still appear as 1400km till service. Any idea why??
Bro what model of your car ? It's works on my E46 but there other model im not sure wor. Btw did u follow as same as the instruction step by step.
E46 2004 318 (N46B20). Yeap did as per Montoya suggestion but still unable to reset back to 20,000km from 1400km
Alex5522;592503 said:
Did u press the right button as mention ? The button near the fuel gauge.
Yeap did as per mention, Still unable to reset it back to 20000km
I've reset mine just now.. it's working reset back to 25k :)
thanks 328 e46 M52TU
I think you didnt follow the step well.. this technique had been discussed a lot of time :) Google it maybe you need other than just a simple reset :)
