kanos
- Sep 14, 2007
- 60
Everyone,I put up this DIY just to share with you on how to reset service interval since some of us with due warranty period. i just refer to www.bimmerpost.com DIY but no pics and the steps are not quite clear. It took me 1/2hr earlier to figure it out and with some photos i uploaded hope it will help.STEP1:Insert key into slotSTEP2
ress Start/Stop button once without depressing brake and you'll see all those warning signs in red and amber.
STEP3:Wait until all the signs disappear as below
STEP4:Immediately after the signs or service reminder disappear, Press and hold the odometer and after 2-3 sec a warning triangle will appear as below.
STEP5:Keep the odo. button pressed and after another 2-3 secs the Oil can will appear or whatever next service is about to due. In my case air filter require change next in 17000km....i'm using K&N .. so can reset anytime after cleaning the filter heheheh
STEP6:You are now in the service menu, use the toggle switch on indicator stalk to scroll up/downthrough the various service items.When you have the item you want to reset showing, press the BC button on end of indicatorstalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secsand a clock will start whirling around and hey presto, its done
Remember on STEP5 if you keep holding the odometer reset button, some German writing will appear and you have to back to the beginning and start again.
Last but not least, I accept no responsibility if you break your car, this is done at your own risk....:wink:
