I own a Land Rover TD4, bought from new, it was last batch of Freelander Series 1's. Its the wife's daily driver - DU to KL every day. It also does multiple DU-KL-DU runs in any given day.
Have been relatively trouble free so far. Presently at 80k kms with 20k kms left to go before warranty runs out.
It starts every morning, no issues. It broke down once - battery exploded(!) it was a freak event which was fixed under warranty.
Warranty claims have been a breeze with auto connexion/sime darby keen to maintain owner confidence. You just need to ask.... and so far I've even got a plastic control knob changed under warranty.
The concern over high cost of parts is not unfounded.
Yes, PARTS ARE EXPENSIVE. Labour is too, but apparently there is a specialist in Batu Caves owners can consider when warranty runs out.... so that's one way to cut down on costs. Also put in perspective ....I think Landies are expensive in the same way Alfas and Volvos are (assuming you are buying ori parts from main dealers).
Generally speaking the 20k kms service interval will typically be around RM500-700 but can go up if something else needs changing. More often than not it will be the brakes, either the rotors or pads will need changing. Its a heavy car and if you travel in town most of the time brakes wear out quickly due to stop start traffic. If brakes are involved it MAY touch RM1000 or close.
The 40k kms is like an inspection 2 on bmws... so this is the biggie. It has touched RM2k plus for me before. For this one they will change ALL filters and oils (inc pollen and little filters here and there it adds up). Invariably brakes go around the same time as well so that adds up.
My concern will be the auto gearbox. It will likely be expensive for rebuild/new. But this is true of any large continental car. My only comfort is that they do change ATF filters and oil every 40k as mentioned above sao none of that sealed for life shit here. I dunno if there is an ATF cooler, that would help with longevity...... lets put it this way - daily driver + kl traffice + our hot climate + style of driving = all this conspire to kill the gearbox.... its only matter of time.
BOTTOM LINE
Judging from how you are fretting between the civic and the Freelander I'd say you are better ofF with the Civic.
The civic does everything very competently. Hard to beat.
You must WANT to buy a Freelander..... its a bit more difficult to justify.
For me? I'm waiting for the warranty to run out....
Thanks for the enquiry. With the TD4 we take power and torque from 110 BHP and 189 lb/ft to 140 BHP and 227 lb/ft. The upgrade is undetectable by Land Rover service and diagnostic equipment and can be carried out at your location. Cost £495+vat.
Kind regards
Mike Cooper
DMS Automotive,UK.
