So was your front alignment okay? or out? Which wheel out? By how many degree?
Since "Manji" only mentioned 3 possible causes which result to your front right tyre wear, seem nothing wrong with your front alignment wor?!?!!
Were u underinflated? What was the pressure when u reach "Manji's place? and what pressure u running now?
Driving style? Lots of left turn braking in the corner?!
We don't brake in the corner girl, we brake before the corner, and accelerate or balance the throttle in the corner..
When I go to tyre shop, I will want to know exactly what measurement was set to my car so if I don't like it, I can up or down the setting by couple of notches.. :wink:
The measurement for camber degree and toe-in degree is the most important to jot down.
Like this (B4):
Was told my front is within spec while my rear was out. My front tyre wear confirm the spec is within. You will notice before my rear camber adjustment the rear left camber was -1.30 but in green color which denotes within spec, however, I suffer serious inner wear with the tyre, so I ask the forement to set -1.10 for me. This is what I call "personalised" set-up, based on my driving style..
And Rachel, what was your fuel tank capacity when u did the alignment job? and what is your usual fuel tank balance? or in other words, when did u refill? Refill when low fuel warning lighted or at quarter tank? What I'm trying to say is if you did your alignment with a little fuel in the tank while u normally maintain 3 quarter tank of fuel, than the alignment setting is too aggressive for u which again, promote inner tyre wear for especially the rear.
