BMW reset tools
i have the R5/FCX II. I'd say one of the best US$140 i've spent.
So easy to reset service, and also read the check engine light.
Its bailed me out numerous times.
Besides...if u get this, then charge your kawan kawan teh tarik everytime u reset their oil light.
Franklin....
Does it help reset failure light . I.e ABS , SRS ..
If it does ... damn ... i need one already .
cheers :D
That i'm not sure lar...i think they have a separate tool for the SRS
maybe the BMW club can sponsor some tools...or get a collection to buy some tools to loan out to members?
Our local BMW chapter does that...buy a bunch of tools (code reader, specialized bmw tools etc) and have a club officer keep these tools and when a member needs it, they can loan/rent the tool for really cheap. Some of the specialized tools cost over US$100.
But this is mostly for the DIY folks.
franklin
Originally posted by three28@Jun 13 2005, 10:57 AM
Franklin....
cheers :D
Bro, the unit doesn't reset faults like airbag or abs ect...
franklin
Brilliant idea!
Originally posted by Raymond@M-BeasT@Jun 2 2006, 09:09 PM
really useful boh????? :unsure:
actually for small faults, the tool is quite useful but big things like SRS and ABS can't do anything. For info, the tool only caters up to E36/E34 and first 2 or 3 batches of E39s.
I just purchased my R5/FCX-II-16 a few weeks ago through the internet. It took about one week to arrive. I tried to reset my camshaft sensor after I replaced it. The fault that appeared was "Intake camshaft position sensor", "exhaust camshaft position sensor" and "air mass sensor". At first I didn't know whether this device could clear the fault. One for sure was that this device can read all the faults. It could also reset the MIL (malfunction indicator lamp such as "check engine" or "service engine soon"), "oilservice" light and "inspection" light. The R5/FCX-II-16 would not reset the brake lining light, the SRS/airbag light or the ABS brake light. Later I went to AB just to be sure. From the diagnostic result it was apparent that this device did a great job. My R5/FCX tool is quite small and handy. I would say it is half the size of my fist. It came with a pouch too. Worth having it.
Got it from a website.Forgot which one but it works.Plagiarism not intended.
Instrument Cluster SIA Reset
For model: E38, E39, E46, E52 and E53
Production date: E46 from 9/99 and E38, E39, E53 from 9/00
On 2001 vehicles without the diagnostic port in the engine compartment, the use of the SIA reset tools in not possible. The service indicator may be reset using the reset mode in the instrument cluster.
• Ignition key must be off
• Press and hold the trip odometer reset button in the instrument cluster (left button), and turn the ignition key to the first position.
• Keep the button pressed for approx. 5 seconds until one of the following words appear in the display: "Oil Service" or "Inspection", with "Reset".
The service due is shown with "reset" if the coded minimum consumption limit has been reached and resetting is possible. If "reset" is not shown, the minimum limit has not been reached and resetting is not possible.
• Press and hold the reset button again until the word "Reset" begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval. After the display has shown the new interval the following will appear: "End SIA".
The system can only be reset again after 2.5 gal (10 liters) of fuel have been consumed.
E46 service interval reset
Keep Button pressed for 5 seconds after key is switched on. Tap button of reset display.
Reset procedure for clusters with SIA IV using the reset mode (possible form 9/99 for E46, MY2001 E52).
• Ignition key must be off.
• Press and hold the trip odometer button in the instrument cluster (left button) and turn the ignition key to the first position.
• Keep the button pressed for approx. 5 seconds until one of the following words appear in the display: "Oil Change" or "Inspection" with "Reset".
• Release the reset button and press and hold again the "Reset " begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval. After the display has shown the new interval, the following will appear: "End SIA".
