1. Do you have problem starting when you leave the car overnight? - Sometime have to crank about 2 to 3 times but no problem after the car is started.
2. Do you sometime feel the car is hesitating when the fuel tank is below the quarter tank? (Like there is no petrol)
If YES, then you have fuel pump problem. To confirm, use special function test and choose menu "6" for the monitoring the Left and Right Fuel Tank level.
When Full, it will indicate "240330". When the Fuel Indicator show half tank, check the indication, it should show "000280".
It the first 3 digits show something, it mean that there are fuel in the left tank. This mean the fuel pump is not strong enough
to suck the fuel from the left tank to the right tank via the return fuel line (vacuum jet pump).
Hi Jarance, i will answer you one by one.
1.) Do you have problem starting when you leave the car overnight? - Sometime have to crank about 2 to 3 times but no problem after the car is started.
- Yes i did have difficulties in starting the car if leave it overnight. This car is weekend drive only so i typically leave it parked for 3 - 4 days. However sometimes it just fire up nicely eventhough it was parked for 3 - 4 days.
- Actually i can't really detect hesitation at all. I always pump half tank for this car, but right now its at quarter so let's see how.
How do i perform special function test as i do not possess any scan tool.
