blutooth E60
There you go,What Saat just said could be the case.Like in my case,I have the Navigation Icon but Sat Nav bo liao....but my bulu tooth is working just fine and if you get the Iphone it works like a charm(eat your heart out..hehe)....Me? I ended up with the Garmin GPS lo
Hi chanbc,
Latest update on the bluetooth problem. When i took delivery of my car, the bluetooth cannot connect. Later found my cd changer and cd player not working. Managed to changed both items for free (under warranty). After that still bluetooth not working or working intermittently. Further inspection found the 'Audio Gateway Computer', dunno whether its the correct term or not, is not working. Changed the computer and needs new programming. I'll keep you posted on the latest update as i will only get the car back this evening. By the way, i sent my car to iktikadraya service center at jalan pahang.
Hi chanbc,
Got my car back this evening. According to the service manager, the've change the idrive computer and reprogrammed it again from version E060-06-06-510 to E060-08-09-530. Costs about Rm3700 for the computer and Rm900 for the reprogramming of the ECU. Hope this info helps.
I have problem with my bluetooth as well. Sent to AB, they said my BT module is faulty and required replacement which will cost me RM2.3k. Currently having the function disabled, before that, can't even use the idrive...
Is there anywhere else I can get the similar replacement done and have the new module programmed?
