Blowing huge amount of white smoke from tail pipe only after taking LH turns??
MalayCooper
Hi as the title says, my car starts fine everytime, no smoke and no smell. But as i drive off and take a Left Hand turn, once i get back on the straight and try to accelerate... HUGE amount of white smoke blowing out of the tail pipe and this will last for about 4-5 seconds or less if I let go of the gas pedal. Funnily, this does not happen on RH turns... or if i drive on the highway and dont take the LH corners as spiritedly...Once fully warmed up she rarely do this, at most times will drive just fine the whole day... Am i correct to suspect one of the valve stem seals are leaked/perished and leaking oil into the combustion chamber? I dont want to remove the cyl head unless I can pin-point the exact problem 1st... FYI engine pulls to 6200rpm real good all the time. Just the occasional white smoke making the car following behind panicked and flashing his/her lights furiously at me LOL.Any ideas?Syed
Hi MalayCooper...
What is your ride...
Sound strange only left turn got white smoke but right turn nothing...
I'm a newbie just wanna know what is the actual prob here...:burnout:
Volvos525i;825582 said:
Hi MalayCooper...
Sound strange only left turn got whhite smoke but right turn nothing...
This:
1980 735i with L-jetronic fuel injection :)
