I have done some shopping around for the GM 4-speed gearboxes, and this is what I found out. There are several factors in gearbox prices. My choices listed below in order of preference:-
Option A: Rebuild own box:
Prices starts from RM3K. Depending on the condition of the GB and the parts required, prices may increase. As the repair kit and tranny oil adds up to almost 1.5K - 2K, 3K seems reasonable for rebuild, IF no other parts needed to be changed. 2.5K sounds really really reasonable in Albert's case.
Pros: U are assured that the damaged parts are changed and yr box is practically new.
Cons: Cost of rebuild cant be fixed till the box is opened and damaged accessed. Usual damage: RM3K (if u very very lucky) to RM5K (if u very very unlucky).
Option B: Recon:
This usually means getting it from a gearbox specialist, who rebuilds the boxes for resell. Depends on where u get them, the boxes are usually old boxes rebuilt from other spoilt boxes, or from potong shops.
Pros: Cost is fixed, depending on where u get them from, ranging from RM3.5-RM4.5K, warranty 3-6months.
Cons: U dont know the source or the original damage of the gearbox, as well as how extensive have the repair (or rebuild) work was.
Option C: 2nd hand (aka potong):
This usually means boxes that are taken from (1) cars involved in accidents, (2) half cut imported cars, (3) stolen cars, or any other sources.
Pros: Cost is relatively cheaper than the options above, E34 boxes starts from RM2.5K.
Cons: U really dont know the original source, and worse still, no assurances of the condition of the gearbox u r getting. Meaning the box could die on you on yr way home from the workshop. Also, warranties are usually not given at all.
There u have it, all the options available for GB, with my personal pros and cons. My personal choice, Option A. It may be the costliest, as u change the rings, clutch plates and get the soleniods changed too, but the pros outweight the cons, as u r assured of a "new" GB with all damaged parts replaced. This gives me good sleep at night as i dont worry of the GB dying on me the next day.
Some advice for those of u doing up yr GB, tell yr mech to rebuild yr torque converter too. There is a clutch plate in it too, and as u have opened up yr box, the cost to replace the clutch plate in the torque converter is minimal. If u r buying a recond GB, u can try to find out if they did rebuild the torque converter. From experience, RM3.5K buys u a recond GB without work done on the torque converter.
My 2 cents, meant to be info shared. Pls down yr own legwork and decide what is the best for you.
5201.
