Alternative to E30 M40 in-tank fuel pump
Originally posted by zaskar@Oct 18 2005, 12:08 PM
Anyone tried using other external pumps for m20. Fabian, can proton wira pump be retrofitted to fit e30 external type. Also read somewhere that merc pump an also be used, Kinaka any comments
Yes the Merc external fuel pump can also be used..but make sure it's the right psi.
Btw, have you solved your problem this morning?
Yup got my fuel pump running again, thanx to zoggee's modic II (aka. whack it and see if it runs). Thats why need sifu's advice on whether to go with ori e30 external pump or retrofit with other brand pump. I heard bosch pump also can use but abit noisy.
Aiya....M20B20 chrome bumper E30 fuel pump always the culprit.I ask before , new will cost you a bomb!! :D Yes its external pump.!!
So I use the aftermarket Bosch fuel pump... pump lor. B)
Originally posted by Zoggee@Oct 18 2005, 02:38 PM
Aiya....M20B20 chrome bumper E30 fuel pump always the culprit.I ask before, new will cost you a bomb!! :D Yes its external pump.!!
How much is this Bosch fuel pump for M20B20 chrome bumper E30??
My fuel pump will get very noisy after a long distance drive - PZYYY..... :blink: ! Is this the sign of weak fuel pump?
hehe nice one fabian......you are very resourcefull.....hmmm cable ties again. haha
Hi all, seems like i'm also facing the same problem but dunno it is really becoz of the fuel pump.
how to do some DIY diagnostic in order to confirm it is the fuel pump oledi kong. car can,t start to send to workshop
thanks for any help :D
wow very intresting indeed , so where is a m43 318 pump located ? internal or external ?so buzzing sound is the sign of konging fuelpump i suppose ? can i change it to wira type ?
anyyone can help on this car still cannot start? Thanks
Problem: Have to take 3 to 5 times to start the engine when engine is warm. Suspected fuel pump pressure low.
Impact: So many time starting engine can spoilt battery and engine starter.
-Bought japanese 1.8 automatic fuel pump (intank) RM170.00
-Make sure it comes with the filter.
-Fuel pump hose. (around 6cm long for modification from original bracket)
-Do a bit modification to fit the original E30 M40 intank fuel pump bracket.
-Problem solf.
Originally posted by fabianyee@May 10 2005, 09:42 AM
M20 uses external fuel pump... external, i think, even easier to fit aftermarket fuel pump...
hi can u help explain, diferent between ext and int, thanks. my car is 3201 y85 i assume it is m20b20. but when i open up my rear seat, i steal can find the fuel pump. is this int or ext.
thanks
Originally posted by zaskar@Oct 22 2005, 01:26 PM
Bosch Fuel Pump RM385
Fuel Filter RM45
Fuel Pump Relay RM115
is this price for new or used item. thanks
New price, but since i have all the parts as mentioned and found out that none of the above were faulty, i guess you could try the parts first to see if they are actually at fault. Are you convinced its a fuel supply problem? tyke also had same problem a week back but found it to be ignition coil. Other times it could be spark plug leads, fuses, distributor or in my case just worn wiring. Best you get your mech to check it out, no point guessing. Also it would be good if mech/you have a ohm meter to check.
Originally posted by fabianyee@May 3 2005, 12:51 PM
the wira fuel pump after being retrofitted onto the ori bracket....
in the haste to get it done, I didn't take the 'before' photo....
Fabian I think the cable tie would not last. You can use a Stainless steel hose clip to do the job better. :D
thank god, this morning i whack my fuse box suddenly, can start whhoaaaah but with my emergency jumper attached.
i think the relay got problem but dunnow which ? but know batt plak kong.. sent for recharge at shop, they say batt kong cannot be used oledi. but i insist to charge. actually how they know bett kong or not ah? :D
on retrofitted, do we need to send to a mechanic, or we can do it ourself. how difficult it is. how long have you use this wira 1.8, discover any problem?
You can do it yourself if u used to DIY. Not too difficult just need to be creative to retrofitted it. So far already 2 month without any problem.
willing to guide u if u need assistant.
FYI...al models pre 88 is external post 88 internal...
Me got da same problem...my mech gave tip... only if fuel pump not knonk den can try tis...release da fuel cap n step on da trotle for a few times before starting...mine has lasted for a few months d....but i think its time to do da change...
So if anybody spots a faded red 4door bimmerby the road....tat might be me...
