Air Flow issue?
ichi82
Sifus..I have a situation right now. when i start my car it seems like there is some air flow issue with the exhaust.. it would initially sound bub.bub.bub.bub for few seconds then back to normal..this happen during cold start and after long duration of parking like end of day after work..my car is N42Thanks in Advance
ichi82;842378 said:
Sifus..
Thanks in Advance
i've the same thing too, sound like missfiring thn vibration...thn after warm up is ok ritez....i heard is the idle control valve..
yup..have you changed the said part?
hmm, not to scare u, but it might be water has been sipped into your combustion chamber (on top of piston will have water, like sweating)....
for the first few second, its been missfiring because of the water mix...after some time, all the water gone....
happen to my n42 before and i decided for top overhaul..
adviseable to clean the MAF sensor which one of the common problem if it got dirty
