AFM Service.A lot of people seem to have a lot of problem with their AFM (me including)When the AFM is giving problem, your engine rpm is very eratic at low rpm.Sign of black smoke is evident when the engine is cold. If you have any of this sign, most probably your AFM is sticky.Note: One good way of clearing this problem is give the AFM a thumbto release the sticky vanes or flap. However, the problem will come backafter a few days. Permanent solution is to service the AFM. It can be done but you will needsome basic tool to do it.Here is the way to do for those are DIY.1. Remove the 4 nos. of spring clip to the air filter. 2. Loosen the hose clip with a flat screw driver (or use a 6 size spanner).3. After you losen the hose clip, pull the AFM from the air intake hose.4. Check the vane or flap of the AFM.________________________________________________________
