bro,the Classic Star is service center?
if i want to buy the absorber only,can make it?
can only buy the front for the Sachs Advantage??i think my front absorber is time to replace it..
btw guys, i fitted my 20inch, with standard absorbers, now when on highway, same road not so firm, so sometimes the tyre touch the fender, wonder if i change to harder absorber will it help?
Definitely but you may need to change the spring as well. Riding on hard absorber & oem spring gives you a very hard ride. Especially if you're on Bilstein monotube, it has reduced stroke compared to twin tube hence it need higher gas pressure to prevent hitting the bottom of absorber casing, which result in harder damping of absorber. Even worse if you have soft spring rate.
bro you want comfort and sport go for Bilstein B12. It's a combo of Bilstein B8 + H&R Springs which is developed for the B8. I am using it and it's Awesome.
