2 potential problem for my bimmer
diarrhea
hey guys.i'm using a pair of 18inch rim with bilstein's suspension package. it gave me quite a nice lowering look. but now my car is jumpy(well obviously la..and i dont really mind)...what i do mind is the sound from the tyres, they are damn bising...btw im using bridgestone tyres. size i'll findout later. is it normal ka to have such noises after using large rims with low profile tyres...its like im driving a 4x4 car with offroad tyres la...damnit..is it the bearings?i have 2 open my car lock manually la. anyone experienced same prob? remote not working. and its as if i dont have an alarm system.any comments sifus?
diarrhea;319033 said:
hey guys.
i'm having the same problem too, d rear tire is damn noisy while running, been checked with some mech, they told me it caused of d tire, one of d rear tire thread worn out, thats why this happen, n my tire size is 255/35/18. Its nothing problem with d bearing, its ur tire.
some toughts...
Tyres produce noise due to:
1. Type of compound
2. Tyre weidth (the larger means larger surface contact)
3. Thread pattern
4. Groove dimension
Ideally, tyre for Malaysia's climax (unpredictable weather) has to be bigger groove which will produce extra sound level but can be reduce with softer compound which will increase tyre cost and of course wear and tear will be more faster. The reason for bigger groove is when the the tyre surface contact with road surface, the outer groove surface will reduce due to the forces and our hot environment but it must be big enough give way to water in wet condition. Small grooves of course will create lower sound level and slightly better traction but will not suitable for wet condition.
Different from other country they may change tyres every seasons change......just a tought.
:rolleyes:
Wider tires does not mean larger surface contact
Usually just change the shape of the contact patch.
Cheers
owh
owh ,
thank you LORD!
hahah looks like my cash are safe in my wallet, for a while
hahahha . anyway anyone has any idea on what happened to my alarm system, or having the same prob??. man, 2 of my friend's honda was stolen within 10 days apart
last month
.scared the crap outta me la. btw, thanx turbo,hafizul and evil :top:
alo bro...as 4 dis prob,i'm not sure bout ur ride model. but my ride has d sensor @ d rear view mirror. so have 2 pointed out d key towards d sensor wen about 2 unlock ur car...
found out bout dis from d forum oso lor...so, sorila if i'm wrong!!!
