1.3 Motronic Up-Grade & 2.7i How To
kenika65
1.3 Motronic Up-Grade is for 1982–1987 E30 325/325e/325es:top: The 86 eta motor is bullet proof but lacks the fuel, electronics and red-line to run properly and efficiently. The up-grade to 1.3 Motronics from 1.0basic Motronic is highly noticeable and recommended.This is what I am running in my 1986 325es, stock 86 325,e,es (Crank, Rods, Flat Top Pistons, head, and cam) with 1.3 Motronic Up-Grade.*Once 1.3 Moronic is swapped in you will rev past 5300rpm so you will need to install the 7000rpm i tachometer*Double valve springs are preferred for high rev applications but you can run the stock 86 single valve springs untill you are ready to take the head off.Everything else if from a 89 325i 2.5(double valve springs, valve cover, exhaust manifolds, exhaust, intake manifold, throttle body, injectors, AFM(air fuel module), FPR(fuel pressure regulator 3.0bar), all pulleys(fan, water pump, crankshaft), alternator(90 amp), belts, thermostat housing, 173ecu(computer in glove box), all 1.3 Motronic wiring and sensors, coil, wires, plugs, fuel tank, fuel pump, fuel lines,flywheel (lighter), transmission (better shifter design), starter, drive shaft, differential (4.10 from a 325ix)).*A 30amp fuse will be needed in the fuse box for the fuel pump.*1.3 Motronic wire harness is larger then 1.0basic Motronic harness so the inlet hole on the firewall passenger side will need to be slightly enlarged.It seems like a long list but will only take a day or three to swap parts.*None of the i parts will increase your rev limit (5300rpm) without the 173ecu 1.3 Motronic up-grade and for higher rev limit try out various performance chips.After upgrading to 1.3 Motronic I now want to try the i cam in the eta head. The eta head will need to have oil passages drilled for the 3 extra cam journals at a knowledgeable machine shop.Then I can put a 7 bearing cam in the eta head. With the i cam installed I will now have a higher power curve!If I still want more power Ill find a 1988 325,e,es 2.7 (super eta) which is the only year with 2.7 domed pistons. These pistons will mate with the i head and have proper compression for NA applications.(e Crank, e rods, 88 super eta pistons, i head) is the most preferred and valued combination with stock bmw parts.If I cant find the 88 super eta pistons then I will go with custom non-interference pistons that will work with (e crank, i rods, i head).The i rods are longer then the e rods and will rev better because of the rod ratio. This combination is better then the stock parts combination.If Turbo is in mind I will use (e Crank, e rods, e pistons, i head). Because the i head has domed combustion chambers unlike the eta head which has flat combustion chambers, the matching of the eta flat top piston and the domed chamber of the i head will result in lower compression (which is perfect for turbo applications). The i head will bolt right on to the stock eta bottom end with no machining needed. The only problem is rough idle and hard start, which can be fixed with advanced engine management like MS2.Here is quote from Wikipedia.com supporting the 2.7i and explaining the 1.3 upgrade.For the 1988 model year, the eta cars got a refresh from the factory. This included a newer Bosch Motronic version with adaptive idle control, a 325i head casting with the larger valves, ports, revised combustion chambers and water jacket, new pistons to fit the 2.7 L stroke with the 2.5 L head, a dual exhaust system and a 5300 RPM rev limit. Though it only made slightly more power in stock form, it could be easily boosted by bolting on a 325i head, a complete 325i intake manifold and throttle and plugging in the 325i engine control unit. Depending on which cam, chip and intake is used, the combination can make over 180 horsepower with the stock compression ratio.In aftermarket modifications that are inspired by custom versions of Alpina and AC Schnitzer, the long-stroke eta engine block is often combined with a 325i head to a so-called 327i that combines the high low-rev torque of the eta with the top-range power of the 325i.http://en.wikipedia.org/wiki/BMW_M20E30ManualHaynescomplete.pdf (application/pdf Object)E30_tsmanual.pdf (application/pdf Object)DME_1.1_1.3.pdf (application/pdf Object)http://shark.armchair.mb.ca/~dave/BMW/e30/http://ee1394.com/bmw/docs/factory/repair/en/index1.htmhttp://pagesperso-orange.fr/s14/index.htmPlease ask questions and leave comments! If you need to e-mail me, my address is kenika65@msn.com__________________:top:
hello mate, i'm in the process of getting the "2.7i" conversion on my E21: 2.7 block, 325 head, L-tronic injection system.
How would I get 200 hp at the wheels. The Danish Kleemans mechanic made it sound like a very straightforward job - but now I'm not so sure
It is straight forward and plug and play. Bolting on a 325i head, a complete 325i intake manifold, throttle, exhaust, up-grade to 1.3 Motronic and plugging in the 325i engine control unit will bring a 2.7 to life and up to date.
I am not familiar with L-tronic injection but think 1.3 is newer and may give better power and less problems, and in an e21 I am not sure if a 1.3 harness will connect to an e21 harness which may be why you have chose L-tronic injection?
As for 200hp... in your situation it would call for extreme port, polish head work for starters and you have flat top pistons which will drop your compression with the i head and need a turbo and MS/2 to see 200hp.
Then you can get domed 88 super eta pistons which will bring up your compression and make more efficient power
Dont fret about taking too much time because it will be worth it when she fires right up!
