X69 Cabrio
GOOD NEWS!!
my baby is back after rewire as old wire burned from radio to relay also replace brake switch and ignition switch
BAD NEWS!!!
However as I reached home and restart the car to test my car.... The engine sputter as if there a misfiring. Torque Pro say cam sensor, misfire on 2, fuel cut on 3.. I shut down the car, clear the code with INPA and the car failed to restart.
Press the accelerator and it start plus everything is back to normal... can this be the fuelpump??? haiyo sakit sakit sakit
new update for my baby 69.. Have seek the help of nitedevil bro to get the followings from Singapore! SGD55 each (front) Please advice if standard or Brembo standard are cheaper or the same price in KL
3411 6 855 153 frt brake disc
attachment.php
anaksarawak;783341 said:
GOOD NEWS!!
BAD NEWS!!!
Problems solved just by clearing all error codes.
Preparing my baby for "Durian" Drive
Fuel Filter - RM120 munich auto
Lamforder Engine Mount RM135 x 2 units Stuttgart
Gearbox mount Lamforder RM30 x 2 Stuttgart
Labour RM 100 @ Kim Leong LDP near Taman Megah and Stuttgard
RM 35 Throttle body cleaning and coil check
Special mention to Melyvn or Slyder for recommending me to this place and helped me get the mountings.
Total Spent RM 595
When for Liqui Moly Jet Clean RM330
Very clean preparation
hose from my fuel tank to Liqui Moly machine (I purposely drive till almost dry and fill RM50 of Shell V Power for maximum cleaning power) :rock:
LM detergent is mixed to the fuel
Fuel is connected back to the fuel line
LM build in filter
Simple vacuum pump with mixer function thats what it is
After the detergent is depleted or 40 minutes, they wash my car. No drama here and my rims still blink blink
Beilstein B6 for my baby.
Front Absorber Mount RM80 x 2
Rear Absorber mount RM35 x 2
Rear bump stop RM 30 x 2
Rear Brembo Rotor RM120 x 2
Front BMW Ori Rotor RM250 x 2
Rear & Front Textar Germany RM220 x 2 (my own from Sime Darby- AB)
Bilstein B6 HD Convertible RM2100 (special price)
Original BMW DOT 4 1000ml fluid RM150 (my own from Sime Darby - AB)
Labor cost RM 300
Total RM4020
Forgot to add..
I have successfully code my aircon to remember the flap position when off via INPA NSC Expert
Tutorial is as follows
To perform Exercise will we need ADS interface for connecting to our Buni kompa + INPA software.
I assume we start in a situation when we operate fully INPA which detects the battery (battery) and ignition (ignition). Details are described in the thread given above. After a successful play INPA comes time to desire change, and here will be the necessary tool, which is called NCS Expert and is located in the Start Menu in the same folder in which it is INPA. Thus, the works.
First Launch NCS Expert (I assume that the INPA package installed in the language we do not speak German).
Second Select File -> Load Profile
3rd In the pane, select Choose Expertmode profile and click OK.
4th Select File -> Edit Profile
5th The window provided a password Passwort eingaben Profile: repxet and click OK.
6th In the editor pane, click Profile Individualisierung button (bottom left)
7th In Memory Car window Individualisierung aktiv checkered flag in the Car / Key Memory and click OK
8th Click the Profile info (bottom right) in the editor window profiles
9th In the info window profiles in the Profile Name with individualisation we add to our profile name sounded Expertmode with individualisation (in this way we will be able to easily distinguish the future from the original profile expertmode) and click OK
10th In the pane, click the Profile Editior consistence check - box should appear with the words konsistence info check OK
11th In the Profile Editor window click OK
12th Select File -> Save As, and in the Profile File Name change to another profile number or FZG3.PFL and click OK
13th Select File -> Load Profile and window profiles have now Choose Expertmode profile with individualisation who select and click ok
14th We take a laptop under his arm and idzemy our Bunia. Hook cables, put our key in the ignition and turn on the ignition (do not fire up the engine)
15th select the VIN / ZCS / FA (F1)
16th Select ZCS / FA f ECU (read data ZCS / FA from ECU our Buni)
17th In the pane, select Choose Chasis E39 (my case).
18th In the pane, select Choose ECU EWS and click around .. after a while, filling up boxes FG GM SA and VN
19th Back F6 Select the options
20th Car Select Memory (F5)
21st We will get the following message:
22nd In this mode of operation window determines whether the programmed key or car (Car Memory / Key Memory 1-4). My Bmka no programming keys so I have not used it, so I'll skip this part to not mess up something. For me, it was just Car Memory. Functions that list of functions which we can reprogram. Unfortunately it is in German and below is a translation of the language (for wreeve of bmwecu.org):
Quote:
E39 Car and Key memory programming using NCS Expert in the Edibas package.
AUSSENTEMP_WARNUNG_GONG: External Low Temp Warning Gong
AUT_SITZVERSTELLUNG: Automatic Seat Adjustment (select when unlocked or when driver door opened) linked to key number
AUTO_ZV_DISABLE: disable automatic central locking
BC_KL_R: Interior lighting ON when ignition is switched off after driving with headlights on
TWO-QUITTIERUNG: Anti Theft System Acknowledgement
EINSCHALTMELDUNG_IMMER: Power-up messgage always
ERKENNUNG_SITZBELEGUNG_1: Recognition seat allocation (do not switch this off otherwise the airbag system gets up-set)
FH_BEIFAHRERTUER_TIPP_AUF: power window Passenger Door Window Down one touch
FH_BEIFAHRERTUER_TIPP_ZU: power window Passenger Door Window Up one touch
FH_FAHRERTUER_TIPP_AUF: power window Driver Door Window Down one touch
FH_FAHRERTUER_TIPP_ZU: power window Driver Door Window Up one touch
FH_TUEREN_HINTEN_TIPP_AUF: doors in rear Window Down one touch
FH_TUEREN_HINTEN_TIPP_ZU: doors in rear Window Up one touch
Fua? Raumklappen: Floor flaps (IHKA)
HBA_DSC_5_7:
HECKKLAPPE_ENTSICHERN: Rear Trunk opening from remote key
HEIMLEUCHTEN: Home Shine (Follow me home lights)
INNENLICHT_AN_MEHRFACH_ZV: Interior Light On Several Times central locking
KEY_MEMORY_IHK Key Memory IHK Module (A / C temperature memory from key number)
KEY_MEMORY_RADIO Key Memory Radio (Radio channel / volume from key number)
KOMFORTOEFFNUNG: Comfort Opening
KOMFORTOEFFNUNG_FB: Comfort Opening remote key
KOMFORTSCHLIESSUNG: Comfort Closing
KOMFORTSCHLIESSUNG_FB: Comfort Closing remote key
LAUTSTAERKE_HINTEN: Volume in the Back
NOTSTROMSIRENE: Emergency Power Siren
QUIT_OPT_ENTSCH: optical Acknowledge remote un-locking (two flashes)
QUIT_OPT_SCHAERF: optical Acknowledge remote locking (one flash)
SCHIEBEHEBEDACH_TIPP_AUF: One touch sun-roof open
SCHIEBEHEBEDACH_TIPP_ZU: One touch sun-roof close
SOFT ON / OFF: Soft dim / undim of the interior lights
SPRACHE: Language selection
TAGFAHRLICHT_ECE: Daylight Headlights
TEMPERATUR_EINHEIT: Temperature Unit (C / F)
Umluft MEMORY: Circulating Air Flap Memory (remembers if re-circ is on after shutdown)
Verbrauch D1: Consumption units
VERRIEGELN_AUT_AB_X_KMH: Automatic central locking after X KMH
VERRIEGELN_AUT_MACH_2_MIN: Automatic central locking after 2 MIN
VERRIEGELUNGSSCHWELLE: locking Device-swells (threshold) (speed of X above)
WEG_EINHEIT: Distance unit (distance, miles or km)
ZEIT_EINHEIT: Time unit (12H or 24H)
ZUENDSCHLUESSEL_WARNUNG: Ignition key Warning, a really anoying beeps Which option if you leave the key in the ignition
ZV_SELEKTIV: central locking selectively (selective unlocking)
Each individual key can also be set to allow selective un-locking and automatic locking after X MPH.
E46
ENTSICHERN_CENTERLOCK: Release central locking
FUNK_INNENRAUMSCHUTZ: Radio monitoring of interior space
FUNKTIONTUERSCHLOSS: Function Door Lock
FUSSRAUMKLAPPE_SCHLIES_1: Floor space flap
HHS_AUTOMATIK: HHS Mechanism
HKL_SPERREN_BEI_ZS: HKL Barriers with ZS
IB_BEI_KL.R_AUS IB at KL.R off
It IB IB_EIN_SCHLOSS_ENTRIEGELN unlock lock
INNENLICHT_AN_MEHRFACH_ZV: Interior lighst it several times
NEIGUGSGEBER: tilt sensor
STANDRUECKSCHALTUNG: Condition Resetting at standing
TAGFAHRLICHT_ECE: Daylight lights
UMLUFT_MEMORY: recirculating air flaps memory
WISCHERINTERVALL: wiper interval
KEY memorys
BELUEFTUNGSKLAPPE_OEFF_1: Ventilation Flap opening
Fernbedienung: Remote control
FUSSRAUMKLAPPE SCHLIES: Floor Air Flaps close
GEBL AUT B ZUEND EIN: blower automatic at ignition on
AUT GEBLAESEBALKEN MOD: Blower Bar Automatic Mode
GEBLAESEKORREKTUR: Blower Correction
Kläppen OEFFNEN: Opening Flaps
BEI KLIMABETR ZUEND EIN: airconditioning at ignition on
HIGH LOW TAKTEN Anzeige: Clocks High Low Announcement
In the parameter we have state of the parameter, the aktiv and aktiv them. Suffix S is the standard we set and I set individual Word Association Game.
23rd Before we begin, you should change the settings But just Read or F1. August buttons grayed out on the dozen / tens of seconds until the car will be read out our current settings. When the button again will we begin to dig black. And so we choose the functions in the center pane then select the desired options in the right pane and press F2 take over. name of the function to be programmed with the state porzadanym appears in the box at the bottom. If you wish to remove functions (not change its state) invades the present in the lower pane and click Delete F3. When we change what we already hit F4 Broadcast and after a while we will see window confirming setup parameters. Voila!
Disconnect kompa and test whether it is just like we wanted.
PS. If you change the settings then it lights when programming (optional broadcast) we start to flashing light and backlight buttons in the middle. For me it was. Programming made it so do not panic.
Anyone want to do this MOD with me? It look amazing!!
Steptronic Sport LED Gear Selector Shifter prewired for E46 (Pictures)
but i will leave pics up for your enjoyment!
Prewired for E46 and E90 3 series steptronic cars. I will also include the original 12 pin wiring-connector as well as extra wiring connectors.
Everything works as shown.
The knob is about the same size as the oem knobs on the E46 and E90 cars.
Knob fits easily onto the E46 and E90 stalk.
Wiring diagram and all installation instructions will be included. As well as an extra set of BMW wire harness and connectors.
Knob as shown cleanly installed on my car. I will also be looking to part out around the start of summer: the heated steering wheel, Rear Fog Lamps and LKM switch, Power Folding Mirrors/Switch, Compass-Homelink-Dimmer Mirror, Homelink BMW Bluetooth Assist-SOS Modules and also maybe the cd53 radio w/ aux-in, mp3 data cd playback, bluetooth, sirius, ipod, etc...
[/FONT]
Is this your car pic bro ?
Alex,
Pictures not from Anaksarawak's car. He downloaded the pixs from another forum (note the car is left-hand drive) to give an example of the modifications.
I thought his car was left LHD since i read the knob clearly installed on my car mentioned :love:
My 3rd / centre brake light when mati last week during Xmas, asked BOMIN they quoted RM500 and Eng Soon Singapore SGD 120+7% GST and need to wait for 6 weeks.
I decided to DIY the repair
Since its a neon tube hence the expensive cost.
Now installed LED from radioshack RM40, used a workshop of a friend so have tools ie heat gun, glue gun, grinder, torque screw and etcs RM40 kopi o money
Connect to BMW Scanner 1.40 to turn the bulb check back on :)
DONE one of my 2013's mod
Darn.... my FC is so high! No thanks to my hill top condo and short drive to office.
I tried to remove the old stalk without removing the steering and slip ring as per UDM68 instruction but failed .... Hahaha I might not have his skillful hands
New stalk installed and plugged in to check if my pre coded with BMW Scanner 1.40 has activated the new stalk
WARNING! Never forget to screw back the centre steering bolt, otherwise you have to redo the whole process all over again. Dont pull the steering if your centre bolt is not secured otherwise you will damage your slip ring, I saw in other video that once the ribbons are out its hard to put it back.
Everything are the same as aidilj's guide but removing the airbag of my car (3 spokes) require the following trick
[video=youtube;_QRmnaQFuZQ]http://www.youtube.com/watch?v=_QRmnaQFuZQ[/video]
How I sayang my baby today.... It took me an hour to do so.
The following video is what I refer to
[video=youtube;QHOOrP1ht_E]http://www.youtube.com/watch?v=QHOOrP1ht_E[/video]
