WTS: M50 gearboxes & M50BTU US SPEC M3 plus M3 cams 3.0
pussy
Post Raya Sales: I have 2 M50 B25 and B18 M44 used gearboxes with dual mass flywheel, clutch, throw bearing, fork and slave pump attached as per picture. The B18 has a rear support broken, but can be welded so no issues, gearboxes are all okay, one was running on my old car and the other is a spare. Both can be fixed to 318 M43, M44; 325, 328 and even M3 engines. Price will be as follows: Official Members i will gave a discount, non OM price is different.M50 : OM RM 2200.00 ; Non RM 2400.00 B18 : OM RM 2000.00 ; Non RM 2200.00 Here is the pictures:
As for US SPEC M3 engine B30, it comes with the Crankshaft, Conrods & Pistons, piston rings were new when installed, engine did 20k kms before removing. Cams are the US spec M3 B30 based and perfect condition. Note all the bearings area are clean and oiled and kept nicely.Piston bore is 86x86 stroke. with this set up, my engine was doing 245hp on crank on standard setup without any mods. With the turner chip setup, was at 290hp. Price will be as follows: Official Members i will gave a discount, non OM price is different.M3 engine internals : OM RM 3000.00 ; Non RM 3500.00 M3 cams : OM RM 2000.00; Non RM 2300.00 - SOLD Here is the pictures:
Note: All the price is fixed and please PM me for sale. Thank you
oh i forgot, for the B30 upgrade, i have the original block with me, just incase if the need requires it..
wah v good prices. for those non-OMs who want to get OM prices, can use my account. just buy me one round masat baik-punya!!!!!:rock::rolleyes:
but bump for good stuff with good prices. if you need complementing lsd or gearing, you can ask me also. hahaahah....
Many calls, yet no wants a stroker... sad, cheapest in the market, last one was sold at 6.5k.....
gearbox still available..
Someone here in the forum very gatal already, says his car so slow....
Dont think his car is slow...he's comparing with mush faster cars :burnout:
Hmmnnn... all asking for the cams only, stroker all dun wan, just ask only...
like that might as well stroke up my M20 engine to B30... sure fast one, at least 228hp on engine, while there, do a 3 angle valve job with p&p and a valve decking...then look for a 272/276 cam...raise the compression to 10.5 then more shoik.... sure hit 240hp...
since when u got m20 la? only m60 wut. :p
after spending all that money, only get 240hp? come la, i got pnp turbo kit for m20. original turbo manifold, no need to modify anything. easy easy 250whp dei!! got one E34 m20 going to get some nice lovin', manual 260box with m20 turbokit. can anyone say 300whp? hahaha.
No la, he wanted to buy the whole set, to replace a broken exhaust cam. Told him no need, as another model can be used.
So, give chance to others la....
