Hi allHave a decent unit for sale, why decent due to the paint, and rear bumper, other are all in good condition.Many wear and tear parts change. Below are some of the job done on this car.Epoxy painted interior floor board [DuPont 2 part]Epoxy painted wheel well [DuPont 2 part]upgraded front ventilated disk actual low mileage,190k Just service and clean head rocker headBlack interiorMichelin tire 80%Change many wear and tear part-clutch set-gear linkage-mounting-absorber-lower arm-rocker cover seal-tirod arm-timing belt-water pump-air filter-alternator-wheel bearing-fan belt-spark plug-oil seal-clutch pump-steering flex disk-long shaft flex disk-fuel filter-Power steering filter- gear box oil seal- air cond cooling coil new.- upgraded aluminum air intake hose.- no rust.Extra Parts:- Ignition coil- brake master pump and servo- front absorber and disk set- 4 unit door with side mirror [ brown glass]- exhaust manifold gasket- rear bumper- many other All in Rm 13,800.00contact no 016-3308031
SOLD
Please help to close tread
SOLD
