Hi guys, i was just wondering if what I've spent so far in 3 months for my car is too much or normal. Thing is,i got it in June and it is in pretty good condition, but some old parts(and expensive!) had to be changed.So i got all brand NEW(no recond,second hand) and i wanted to know if its normal for a car this age.its 1991,so 16 years old. here's the list till today. And when i talk about normal price,it only covers basic car essentials.Not mods!1. Starter motor and labor- RM9502. Fan belt- RM353. Air cond belt- RM404. Power steering belt- RM305. Alternator- RM12006.Idle valve bush- RM607.Items 2-6 labor- RM508.Oil filter- RM349. Semi Synthetic engine oil- RM89 (4litre)10. Gearbox oil- RM2811.Labor items 8-10 - RM3012. Spray rear bumper and eyelids- RM40013.Rear bumper- RM28014.Interior light (one set)- RM4315.Idle valve- RM60016.Brake disc front one set ventilated- RM20417. Output cylinder- RM8018.Labor to replace new camshaft,rocker arm and thrust washer- RM20019.Alignment and balancing- RM4120.Spark plug- RM5221.Service AFM-RM20022. Fuel filter- RM4123.Brake drum and shoes- RM30624.Drag lever- RM38425.Oil seal-RM2026.Camshaft-RM51227.Thrust adapter- RM8828.One long ass list from M1-->holder,plunger,thermostat o ring,bypass hose,thermostat,brake pedal bush,bush,door handle frame,lh door inner handle,bush,powe window switch,washer pump,speedo gear plus labor for- RM184029.Valve cover gasket,timing belt,timing bearing big,small,timing oil seal up,down,light bulb and labor-RM61530.Engine oil cap,air hose- RM9531.Tinting- RM68032.Brake pads- RM9233.Ventilated calipers- RM15034.Exhaust- RM20035. New Bosch fuel pump - RM78036. AFM- RM400Ok all that came to a heart-attack inducing price of -RM 11,000*faints*
