wrong oil filter
southisland
went to do my 8k interval oil change earlier on my E90 325 (N52)...but i just realized the oil filter they used is stated on the box N54 which is an E92 335 engine.any advise from anyone?should i replace the oil filter to the right one or keep on using this wrong one.Thks
Might be a wrong box la. But BMW oil filter not many variants, if can fit, then should be can use la. N54 is twin turbo wor! :top: :D
Update:
Bro! I have checked. Both N52 and N54 is using the same oil filter with OEM filter.
Part number: 11 42 7 566 327
thks for yr confirmation astro...u r the ever reliable guru here :top: the filter looked gd fit to me when they put it in,so should b same filter for both. Bavarian auto confirmed as well.
Southisalnd your car looks like a 335 mah....so gotta use the 335 oil filter lor...
Astor checked & confirmed that both the engines are running the same filter, so don't worry ya...
Can try to use www.RealOEM.com whenever you need to confirm if you are using the right parts....very extensive exploded view of almost everything on our BMW
hehe... that's what I used.. :listen:
While at it... I am looking for part numbers for the E46 N46 dipstick to use it for E90 N46.. :p A handful of parts involved.. :D and yes, it can be installed!
Oh yes, I have checked the E46 318i N42 and N46 oil filter, both using same oil filter as the E90 N46. So I can just walk into any spare part shop and get E46 oil filter for my E90.. :p :D Who knows, might be cheaper.. :p
blk E90...dont b so kuacheong la :smile: didnt know abt the website to check on parts...thks for sharing Zeedo.
I oso want a dipstick astro!
Aiks, I only research on N46 engine, now pulak need to research for N52.. darn... I should have bought N52 in the first place.. :p :D
Wait, I'll get u the part numbers.
Update:
N52 is debuted in 2005 and first car to adopt this engine back then was E60 523i, year 2005. I have check the catalog, this model has 2 oil pan design, one of them same like yours but both also no dipstick. So confirm no OEM parts for u unless you want to use the E46 M54 dipstick to modify (O-ring size also different at the oil pan mount for the M54 dipstick guide tube).
Check out the side of your N52 oil pan, there is a hose (thumb size :D) going in now, that's you oil return hose and that's where u gonna stick in your dipstick. :D
More about N52 here, with loads of photo for your engine.. http://www.mwerks.com/artman/publish/features/article_960.shtml
On the other hand, E90 N46 can use the following E46 N46 parts to install dipstick.. :D
1) 11 43 7 505 490, Dipstick
2) 11 43 1 717 666, O-ring
3) 11 43 7 505 011, Guide tube
4) 07 11 9 900 268, Hex Bolt with washer
5) 11 43 7 509 343, O-ring (Production discontinued)
6) 12 52 1 732 530 or 11 78 7 549 563, Cable clamp
:D :D
:D :D
Bro, the O-ring is no longer in production leh...so you gonna use a rubberband ar...?
if need to modify to accomodate dipstick....will forget abt the idea of checking oil color on dipstick for gd liao.
