E3six
Senior Member
- Dec 8, 2004
- 442
Dun know exactly what to call this...but the question as follow:-I been using open port K&N filter for sometime. Just recently i accounter 2 water hose has been blocked due to no in use in open port filter. this bcos those 2 water hose need to use when only used back the old filter box. pix show #16 is connecting to thermostat (#11). what is the purpose of this thermostat being there ???? If you trace the connection ( attachment link) , it is to throtle then come in back out. izit for the cooling of throther body ???? what if i block the 2 hose showing #16 to thermostat #11 and take out the thermostat, will it cause any problem or damage to the throter ????pls help. Thanks in advance(pix show on this link)http://www.realoem.com/bmw/showparts.do?mo...142&hg=11&fg=35
