xponggos;393163 said:hallo bro, i m using E36 325 i. 1994 model. i m having problem with my water coolant .....have to topup every 2 day or after long distant travel ( ie. bworth - kl) . dah hantaq kedai, checked with special tools (sthing got 2 do witd Co2 and blue luquid) to indicate leaked....tarak leak pong...taro green coolant nak tgk kot-kot ada leak kat paip ke radiator ke......tarak juga....so could you guys advice me on this particular prob. so far i've never experianced overheating.
azam318;393519 said:Bro, I'm seeing similar problem as yours, last time. My problem was the radiator leaking at
the bottom and the spare tank oso cracked with a small lubang. And after a sudden, the
small lubang became a big hole, one day I kena overheat at Seremban highway, the temp
gauge from middle to the max level in red color. Just pull over and found out my radiator
and spare tank pecah... sigh.. apa lagi tow lar... lesson learnt for me, no more delayed to
change the parts if oledy encountered the problem.
So, may be you can try to check your spare tank and radiator to see any crack on that stuffs.
Good luck :wink:
beemer04;383296 said:My e36 has got a loud noise, not while driving and cruising, sumthing similar to roars, could it be the cluctch fan (maybe) not or the wheel bearings? Any advise? The car is in Malacca, and I have no idea where to send to a reliable mechanic?
loafer;393537 said:When it comes to engine cooling system never ever delay. Lucky nothing happened to your engine bro. Hope everything is tip top now.
cheers.
beemer04;385560 said:Guys I have bought the rear bearing FAG at RM95 each,
Crymson;393651 said:I think your mech would do a compression test to see if there is a leak or not. Then he would estimate where it is from and inspected to suspected leakage area.
2 weeks ago my OBC told my coolant level was low, so I topup with water. Later after driven to another location, I found that there are drops of water underneath. So I went to my mech and he did a comp test. He open up and found my reserve tank have a small crack (although I had it replace 1 year ago, this remind me not to go to the other mech again). I changed that and now it's ok.
