bxnut;420728 said:Well guys,
I've done it. Went to BIMMER auto. Got the gearoil and filter changed. Also due for service. Had to do 100,000 service too. He also changed air cond belt(cracked), and a sensor at the radiator. Total damage was almost $1200.00.
Gear shifts are the same. But the problem seems to have disappeared. The pick up is much smoother and faster now.
Unfortunately as luck would have it, the next day, my rear right window refused to go up. Had to book into AB Sg Besi for Wednesday.
Selvam of Bimmer auto says an extra cooler for the gear box would not be wise because:
1. High pressure system might leak.
2. Not much space down there anywhere
So, for now, I'm off the idea.
Can give a breakdown price of all the works carried out.
Thank for the feeback and outcome. Glad to hear that the GB feel much better.
You should have applied silicon grease as countermeasure to prevent the window from being stuck. Now plastic slide is broken and have to replace all the window. there are some who can do the repair for under RM1.
