Trans Failsafe Prog...Finally solved
Does e39 without OBC have this trans failsafe prog indicator on the dashboard cluster? Thanx in advance
Same thing happened to me. I just changed the gear transamission oil and voila, all the lights are back to normal. Changing the transmission thing is an overkill. Should have explored cheaper version.
SOLVED too!
The workshop found out the connector wiring that feeds into the gear position and reverse light switch perished (from what he explained).
Just fix the wiring loom (cut and replaced with new wires (tapped) and then walla! everything back to normal.
The car is now smooth and powderful. I have my autocruise and auto-dipping reverse left wing mirror.
Thanks for sharing bros...indeed this is what actually hoped by our members here..sharing is caring..:top:
i have this error on and off for some time already. whenever i am cruising and when this error came out, my engine will suddenly loose power intermittently and i will need to step more petrol to compensate the power loss. i have checked the gears are not downshifted, the rpm juz went to 0. any ideas ?
