Time / Fuel readings auto reset
Iceduke
Hi all,Wondering if anybody experience time / fuel readings reset automatically on the instrument cluster? I've experience this quite a number of times already. It only happens when I fail to unlock the car the first time when I press the unlock button. After 2nd and sometimes 3rd try only it will unlock and then voila when I turn the ignition, time and all fuel readings will be reset. Could this be the battery in the key issue? or the overall car battery? Morning and current engine cranks are ok, fires up almost immediately without long crank times.If not then perhaps need to get it diagnosed...thanks guys ;)
Normally this will happen if the connection to the car battery is being compromise..
i see..but if the battery is weak, should'nt my cold starts be weak? My starts (cold / hot) are perfectly fine.... :)
