jazzler;464829 said:
The general sentiment is that once you go UDM, you'll never go back. Nevermind it being 2nd hand.
The usual prudence of getting a 2nd hand car applies as much to a bimmer as much as any other car. Particularly to look out for is the coolant system and the gearbox. I've also read something about AB servicing but not sure what that means.
And the 318i is a good entrypoint for 1st timer. That's a brief summary of what I've got so far. Anything else that I've missed?
For 318i, here goes the general points:-
1. Buy the one with the steptronic gearbox - I think from year 2000 onwards.
2. Make sure gearbox oil changed before and correct oil as well. Maybe should change every 30-50k km.
3. Power window lifters fail frequently. Budget for at least one to fail every year.
4. Make sure oil changed every 10k km with synthetic.
5. Control arm should have been changed if above 100k km.
6. Control arm bushes maybe every 50k km.
7. Engine mountings if above 100k km.
8. Do the usual checks for oil leaks, brakes (ABS test), coolent system etc.
9. Make sure seller gives you 4 keys, 2 normal, one wallet and one wallet key.
The 1.9 is more reliable than the later 2.0. Generally fuel consumption is good. Not a quick car but solid and reliable if well looked after. You will be slower than the Altis 1.8 and Civic 1.8 if you buy the 1.9 model. Generally, make sure there is a full service history. Then, budget 5k for potential repairs. If no service history, budget 20k. The above is just a short summary. I can't recall everything right now.
