Someone mentioned about me?..
Been sneezing since 1 am this morning..
Some of the technology or design that's commonly found in UDM.. some were used by JDM now and some which they will never use due to economic factor:
1. Window printed radio antenna (E36+)
2. 50/50 chassis weight distribution, battery in the boot, RWD, short overhang, big rear window etc.. (All models ?)
3. Bee hive shape rear spring that can almost fully depressed into a discus shape, and hey! its progressive too! (E36)
4. Slight lifting (6") door edge to avoid hitting road curb when door open (E46).
5. Cabin headlight adjuster (E36 +).
6. Active steering (Later models).
7. Corrective headlight beem (Later models).
8. Internal door handle release central lock (All models?).
9. Passenger/driver/boot master central lock (All models?).
10. Boot handle that can open boot rather than pulling wire under the seat. Now Myvi also can do this. (E36+)
11. Fuel cap that central lock (All models?).
12. Speed sensitive wiper speed, rain sensor.
13. Reset type rear defogger switch so no worries about forgetting to off, Waja also have this..
14. Brake light that can tell how hard the driver is braking..
15. External door handle night illumination for the 1-series.
16. Parking lights.. most continental car has this.
17. When driving on "D", then accidentally push to "R" or "N" also won't spoil the gearbox.
18. "Life time" oil (Gear, differential, ATF, power steering)..
19. Try the Manual gearbox, 3rd gear can go 20kph also engine won't jerk..
20. Some say can drive on 3 wheels..
21. Double bonnet latch.
22. Independent rear drive axle shaft.
23. Electrical brake lining wear sensor on the pad.
24. RFT, tyre pressure indicator..
25. Anti glare rear view mirror.
26. All the interior upholstery is carefully selected not only of its look, but the smell and safety too. They have odor specialist to smell the material to make sure it does not have any dozing effect. Now u know why driving BMW after long distance is still refreshing? and their interior has a unique smell compare to other car.
27. and a lot more that has yet to be discovered....
Every piece of thing is functionally designed to make up the "Ultimate" package.
Owning a UDM is not cheap but look at it this way, u are actually taking part in the development of automotive technology that pioneer the industry.
Long live UDM!
And HAB! U have not introduce urself in the Newbies section le. So we are not suppose to talk to u until u do that..
