The Big Brake Kit [BBK] Photo thread.
insomniac;804766 said:
Is this the botak gay panda from IA? ;P
Now upgrade to Audi & BMW ke?
jibet! Haha there is only 1 subsonique bro, yup it's me. Sudah berapa tahun drive Audi and BMW bro. I still got an Italian with me hehe.
Hahahaha... guessed as much it was you. Looking for brakes for your E46 ar?
I've got 2 options for you if you're interested... LOL!!
One plug and play, the other abit more effort.
I haven't come across any italian that i quite fancy recently... maybe haven't been looking hard enough.
haha i would definitely by a plug and play BBK la. nowadays i don't have extra time to spend when it comes to molesting cars haha.
subsonique;804890 said:
it could be cheap because i think the rotor in the picture is not Brembo rotor. well anyway, do update us once you get the price hehe.
This is a Porsche Cayenne caliper that has had its mounting points machined off to fit custom brackets. The rotor is not branded but the seller says it is manufactured in USA. Price is RM7k+ for fronts only.
thanks for the intel bro.
insomniac;805012 said:
You got PM!
i know! and i got to find a reason to avoid the super good price! hmmm, let me think about it bro (i know i should not, i should just grab it). thanks so much!
I live to RACUN!! Got some other stuff you may be interested in as well but i'll stick to making you dream of those brembo's for the time being. ;)
NKTOB;795973 said:
subscribed.
Front
Rear
Brembo GT Kit Monobloc 6pot/4pot 380mm/345mm cross drilled all around.
Brembo Gran Turismo Big Brake System
The Brembo Gran Turismo High Performance Braking System offers significant advantages over the OE manufacturer's system — advantages far beyond what's simply known as "big brakes". As the braking system's primary function is to dissipate heat, larger, more sophisticated discs are used in order to increase the fade resistance of the system. These discs are directionally vented for enhanced cooling, as well as drilled or slotted for improved consistency, continuously cleaning and refreshing the pad surface.
In most applications, a two-piece "floating" disc assembly is used, with a cast—iron disc specially mounted to a billet aluminum hat. One of the advantages of this type of construction is reduced weight. By making the center-section of the disc out of aluminum, a great deal of weight can be saved in a key location, as it is both unsprung and rotating. The greatest advantage, however, lies in the float itself. The brake discs must cope with extreme temperature levels. In the case of a non-floating disc, thermal stresses develop which lead to warping of the disc and cupping of the braking surface. With the full floating system, the disc is free to grow relative to the bell, and can remain straight and true.
On nearly all the vehicles for which there is a Gran Turismo system available, the OEM caliper is of a sliding design, with the piston or pistons on only the inboard side of the disc. While this type of caliper is inexpensive to manufacture, it is generally extremely heavy, and inherently flexible, both of which are to be avoided on a performance braking system. Conversely, Brembo's calipers are fixed mount, opposed piston calipers cast from aluminum alloy. Despite being much larger and many times stiffer than the original caliper, they are also much lighter. The calipers are equipped with differential piston bores in order to eliminate pad taper. Without this feature, the leading edge of the pad will wear more quickly. This can cause problems such as cocking the pistons in their bores, which can damage or seize them.
Each Gran Turismo system comes with high performance brake pads, aircraft quality hardware, DOT and TÜV— approved Goodridge stainless steel braided brake lines, instruction manual and dye cut stickers for your car.
The net result is a braking system, developed specifically for each vehicle application by Brembo's immense technical resources, that insures high quality as well as high performance.
source : Brembo USA.
hmm that breaking system is looking nice and really powerful. because those discs are looking big then normal size so that's why they have good braking power. Thanks for sharing the photos s of this system. good sharing.
