Sway E36 328
K.M.
Hello guys,I'm in the process of getting my self an E36 328. Untill now I'd test drive at least 8 units of E36 328 which had given me a good knowledge for comparison on the 'driving feel' on 328.Finally, I managed to find a good car in KL had test drive it. The car condition is good and engine also in tip-top condition. The dissapointment is the steering control of the car. The car tends to sway or swing on the road. It's like out of control. I've seen a few posting by Manjit and Primacom on this problem. Is the any solution for this problem?All the car I'd tested before don't have this problem. Didn't expect a bimmer car can have this kind of problem since it's well known for superb handling.I don't think tightening the steering is the best solution. Alignment also is not the problem. Can it be the steering rack or backside absorber.This car comes with 18" ac rim. All the car I'd tested before only have 17" ac rim.Pls advise. Thanks.
Opps...apologize mod..i miss post the thing on the wrong section...sorry didn't realize it. Please tow this to the 3 series section.
Sorry.
Even the newest e36 is already 6 years old. Chances are the shocks and springs are gone, hence the soft handling. But even when new, i suspect the cars were set up a little on the soft side. Most of the 328 guys here swap in lower springs and stiffer shocks.
Another thing to remember is that the auto gearbox lasts around 150,000 kms only. A rebuild can range from 3.5 to 5k. If the shift is clunky between gears, you may have a problem.
Good luck.
With 18" rims, it's possibly 'bump steer'.
Steering rack may be out as well.
