Well what happen today caught me completely by surprise. I went to my regular shop to check out a set of rubber for my E30. I could not decide on it so I got the mechanic to remove my front right wheel to fix the new tyre I intended to buy. I wanted to see how it looked on the car before proceeding with the purchase. To my horror the mechanic told me that my brake have no brake pad. Told me "sudah putus boss"! I was shocked and I said "nolah cannot be". Checked it myself and horror upon horror when he removed the front right pad, the pad materials dropped macam biskut kering. The inner pad was still intact attached to the base metal but the outer pad was completely broken in pieces and no longer attached to the base. I was saying to myself "no wonder the brakes felt so spongy and ineffective". For the first time after buying the car in 2 weeks time, I had a close look at my front brake system. The front disc is ventilated, braided brake hose and the calipers seemed good. However notice that the disc was slightly scorched, guess it would require skimming, I wonder if this is advisable. Immediately instructed the mechanic to check the brakes on all four wheels. Front left had the same problem as the right but the back with solid disc was good.
Changed all pads to ATE and sucked all brake fluid and bled the system using Shell brake fluid. (The mechanic shop is at the Shell Station). I could not wait to get the disc skimmed, postponed it to a later date. Need to check with the sifus of E30 as to whether this is advisable. I do know that disc have a certain thickness of hardened steel to take the braking abration but beyond the harden surface it is not advisable. Please correct me if I am wrong.
Now the brakes are more responsive but a bit low. I now wonder what could be the cause. I have that bit more confidence when driving now. Well good thing I asked the forumers about the brake, god knows what would happened if I had not decided to check out the tyres. I now know, thanks to everyone here with your very helpful help and tips, what I need to do. Only 2 questions remained.
1. Can or should I skim my scorched front ventilated disc.
1. My brakes pedal is a bit low, after changing pad and fluid, what could be the cause.
Thanks everyone.
