Hi bros,Been doing some troubleshooting with my car: Engine refuses to start after crank - occassionally it will fire up and die back again after 2-3 seconds.Checkpoint 1: Is the fuel pump working?I checked a valve at the fuel rails, pressed it and fuel squirted out. Cranked the car once (it died). Check that valve again and there was fuel squirting out.FUEL PUMP OKCheckpoint 2: Is the crankshaft position sensor working?Pulled out a spark plug cable and attached a spare spark plug and earthed it. Cranked the car and the spark plug was sparking.CRANK POSITION SENSOR OKSo what could this be then? There's only one thing left: Stuck AFM. But I just changed it :smokin:Hope to hear your input on this bros...
