Hello members,i discovered a small pipe leak underneath my car (click picture to enlarge)View attachment 23939what part is it and how much to replace? Thank You
That looks like your auto transmission cable, it shouldn't contain any oil. The oil dripping from it should have originated from somewhere above, most likely your auto gearbox gasket.
it happens once in a while... you should change the seal rubber washer.. very cheap stuff.. and does not took long to change. Change the rubber washer near the gear connector there 1st... and wash it up.. monitor it for few days.. normally thats the part is leaking due to the rubber harden already.
GB oil small leak only.will repair next month.regarding the coolant level,i just use pipe water only.my mech said no wonder very fast the coolant level drop.now using mix of coolant and water.so far so good.
