Shaking at low speed
zulkifli
Dear all Sifu,My ride having a bit shaking at low speed below 60km/hr.....anybody facing same problem and to share the solution please.
By shaking, were you referring to your steering or your car. I hope it's the former...
Is your engine RPM going up and down when you drive at low speeds? Also your engine mountings could be gone.
Salut
1. check spark plug and igniton coil first.
2. have you change the fuel filter lately?
Shaking as in Car vibration? Or was it like the engine chocking???
Hmmm Might be as simple as tire balance... But im betting on Sparks/ignition coil...
Nothing to do with engine(excellent)....new spark plug, fuel filter, air filter etc.
Agree wth xcrave...tire unbalance or disc brake wobble.
So after you treat it what was the problem zulkifli?
Tire unbalance and rotor answered it?
Mine had the same issue. Had changed rotor & finally its the tire. Check tire balancing. Should be fine if you done it !
Very busy...not done yet and thanks for advice.
