saat
- Dec 6, 2004
- 1,839
- 48
astroboy;272117 said:This is what I think...
Since tubeless tyres days, I have not done road side flat tyre replacement for all the nails and screws that stuck on my tyres from one inch nail to 3 inches screws.
The reason is simple, as long as the sharp object is still on the tyre, it will slow down the escaping air and in most cases, I can continue to use the cars for days or even weeks!
I make it a point on taking visual inspection on all 4 tyres before getting into the car and drive, every time. If I notice flabby tyres, I will get to a near by petrol kiosk to pump the soft tyres and to see if sharp object stuck on the tyres. If yes, then hit straight to the tyre shop to get them to remove the object and patch the tyre there and then. Done!
As for car pre-fitted with RFT, the tyre pressure indicator still works ma. So u can still monitor the pressure from the cabin and u should get a warning if under inflate. That's the first symptom of suggesting ur tyre might have punctured by sharp object. Get it inspect immediately before its flat.
So really, we don't need RFT, even without spare. Unless ur life is risking people shooting at u with a gun, then better stick to RFT!
You have notv experienced a blowout at high speed. I have had it 3 times.
The last one was caused by a 3" wood screw on my almost new 18" dunlop SP9000 whilst doing 180-200kph.
The tire was in shreds. I think even the mobility kit cannot help.
At that time I changed to the spare.
Blowout resistance is one of the more lesser known characteristics of RFT.
