aidilj;664698 said:This one, but expensive!
http://cgi.ebay.com/ebaymotors/BMW-...r_Truck_Parts_Accessories&hash=item4cf517af6e
jarance;664981 said:Dont think the normal push button will work. it have special connector.
The push button have dual functions.
Push 1 time, it will raise the blind. Push another time, it will lower the blind.
Alex5522;665491 said:
Bro may i know how you cut the bazel to install this non OEM switch
Do you have any idea that the side mirror switch can use as my sun blind switch since i think the wiring connection will be same as the Uni-Button Switch(6 poles but only using 5 poles)
aidilj;665497 said:The bezel was cut using a soldering iron because I have no proper tools last time, now I would use the dremel. The plastic piece can be removed to work on, it is only held down with clips.
You can't just rewire the the side mirror switch to get it to drive the sunblind. Modifications would be necessary. The joystick is just a switch which is connected to a module then connected to the wing mirrors. For your problem you'll need a h-bridge, either solid state or mechanical and in addition to that a circuit to detect if the motor is draining too much current to stop it.. Any kind of switch is doable but modification would be necessary.
aidilj;666274 said:Good job bro, hoping that you'll get a proper camera soon
cythomas83;666276 said:it's nice bro alex
